Simple timing question
Old Mar 2, 2007 | 06:43 AM
WillRadford's Avatar
I was reading a thread yesterday about a kid who replaced a timing belt or something and said he put the timing at 0 and it had no power and then people told him to put it at like 13 or something and it worked fine then. Im confused about where this adjustment is being made. I've done headgaskets on two different 3.0s and when I put the timing belt back on I make sure the camshaft sprockets are lined up with arrows pointing straight up, and I make sure the tick mark on the vibration dampener pulley (is that what its called, the pulley on the crankshaft?) is lined up with the zero on the lower timing belt cover. Things seem to have worked fine on both engines.
So my question is what adjustment was being refered to in the thread I was reading? Something about advancing the timing? What is that?
Old Mar 2, 2007 | 07:04 AM
mtrdrms's Avatar
this refers to the ignition timing (spark delivery) as opposed to the mechanical timing (rotating assembly). The ignition timing is adjusted by loosening the pinch bolt on the distributor and physically turning it. This adjusts where in the cranks rotation the spark is delivered to the combustion chamber.
Old Mar 2, 2007 | 08:25 AM
Oh, so it changes when the spark hits relative to where the piston and valves are. So what is the stock ignition timing? Is it best to leave it at stock?
Old Mar 2, 2007 | 01:06 PM
MudHippy's Avatar
3VZE, 10 degrees. Not according to some, I've seen fellas on this site say as much as 16.
Old Mar 2, 2007 | 01:07 PM
Is 10 degrees stock?
Old Mar 2, 2007 | 01:08 PM
MudHippy's Avatar
Says so in the Chiltons.
Old Mar 2, 2007 | 01:10 PM
thook's Avatar
Also says on the sticker under the hood.
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
