Shocks preference
Old 08-16-2009, 12:13 PM
Hilux808's Avatar
Shocks preference
I just installed 1.5" BJ spacers on my 91' 4Runner and I'm looking for some new front shocks.
Is OME really good? Know of any cheap places to buy OME brand new? Any other brands you can recommend for the 1.5" lift? I know I can choose from Superlift, ProComp, Doetsch Tech and maybe Bilstein. I just want a good pair up front.
If you have BJ spacers on your truck tell me what shocks you're running....
Old 08-16-2009, 08:15 PM
Staff
DeathCougar's Avatar
There are thousands of opinions on this.
general consensus is Bilstein and OME are top notch.
Old 08-16-2009, 08:19 PM
yotaman90's Avatar
I like Rancho, really smoothed out my 4runner's ride
Old 08-16-2009, 09:00 PM
NYChopshop's Avatar
x2 on rancho. My 'runner came with BJ spacers, OME rear springs and rancho shocks. I probably wouldn't have put them on myself, but pounding around the barely improved road systems of New York City with reckless aplomb, I am absolutely floored with how smooth these things ride over bumps at speed that would be bone jarring in any other vehicle I drive. I highly recommend them, if for nothing other than our particular application.
Old 08-17-2009, 02:32 AM
TNRabbit's Avatar
Ditto.
Old 08-17-2009, 05:21 AM
InternetRoadkill's Avatar
Rancho's work well and are reasonably priced. The paint on the outside is not great. Mine showed signs of surface rust within a year, but it doesn't effect how they work.
Old 08-17-2009, 06:13 AM
GorgeRunner's Avatar
I like Ranchos as well. I've used them and gas filled shocks like KYB; the gas filled shocks can give you a pretty harsh ride.
Old 08-17-2009, 09:11 AM
Hilux808's Avatar
Haven't decided on a brand yet, I think I found the right model number of Bilstein's to handle the BJ spacer lift. Some shocks are only rated at 0-1in. of lift, like some Rancho's I've found. Does 1/2 of an inch make a difference since my BJ spacers are 1 1/2"?
Old 08-17-2009, 11:53 AM
yotaman90's Avatar
Yes 1/2 an inch could cause your shocks to overextend and break. I know when I bought my Ranchos I was asked if my vehicles had any sort of lift since longer shocks could be ordered to handle a lift
Old 08-17-2009, 12:01 PM
OutlawMike's Avatar
I have the OME's on my rig with 1.5" BJ spacers, 2" OME springs in the rear.
They fit perfect, even with the BJ spacers, no length issues. I had Rancho RS5000's on there before the lift, they also worked well.
Old 08-17-2009, 12:08 PM
swapped89's Avatar
I dont own a runner but when my truck was stockish i had rancho rs9000's i really liked the adjustability of them. i could adjust the stiffness depending on the kind of ride i wanted. like for offroading i would stiffen the shock to take hard hits. and on the road i could lessen the stiffness for a smooth ride. just my .2$
Old 08-17-2009, 12:10 PM
Hilux808's Avatar
If that's the case then it looks like I have a few to choose from. 4crawler says that Rancho RS5167 will work. 4 Wheel Parts has Bilstein F4B461468H0 listed for 0-2" of lift, also OME N92 and N98 and Skyjacker N8052.
Old 08-17-2009, 12:13 PM
yotaman90's Avatar
Get which ever ones seem like the best deal
Old 08-17-2009, 12:17 PM
yotaman90's Avatar
The only problem with RS 9000s is that they're pricey, about twice the price of RS 5000s (roughly $240 each vs $120 each)
Old 08-17-2009, 12:18 PM
Hilux808's Avatar
The Skyjackers and the Rancho's seem to be the cheapest one's, I'm sure there is a reason for that.
Old 08-17-2009, 12:21 PM
yotaman90's Avatar
Yeah you're not paying for a name, not to knock Bilstein or OME though
Old 08-17-2009, 12:26 PM
Hilux808's Avatar
Rancho RS5167 from Summit Racing $47.95 ea. RS 9000 series about $100 each.
Old 08-17-2009, 12:31 PM
yotaman90's Avatar
Well, now I know to go to Summit first before NAPA
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
ZGjethro
06-07-2017 11:04 PM
dirk89
10-01-2015 05:15 PM
ktm192k
10-01-2015 08:47 AM
Quick Reply: Shocks preference
