searchin but not findin...ditch the A/C?
Old Nov 18, 2007 | 02:48 PM
superscreenname's Avatar
I wanna do away with my A/C system totally. Anyone else done this? Can I do it without effecting my heating system, because I want to keep my heat? THis is on an 87 4 runner with 22re, and auto trans if that matters. Can I just plug the hoses and be done with it and toss the compressor? Any input would be much appreciated.
Old Nov 18, 2007 | 03:13 PM
ncpaladin's Avatar
Yes, you can remove most of the A/C system without any problem with your heat or anything else for that matter. The compressor, condensor, hoses, etc. can come out. Block off the lines going into the firewall to keep dirt and critters out of them. Take care of what you remove, and store them or sell them. If the A/C works right now, I would definitely put the comperssor in a ziploc bag and keep it safe, and cap off the lines you take out for storage. Of course the question comes to mind, why take it out? My 87 SR5 4Runner was born without A/C, and I would be tickled if it had it. Oh, well.
Old Nov 18, 2007 | 03:17 PM
Sweet. I just don't use it is why. It is one more thing putting drag on the motor, takin up space in the engine bay, and one more thing that can go wrong. Plus I have an 07 taco that has really cold a/c for those nasty hot days. I will have the top off this thing all summer anyhow.
Old Nov 18, 2007 | 03:31 PM
881stGenRunner's Avatar
if you dont want to totally take it off, you could just take off the belt running to the ac compressor
Old Nov 18, 2007 | 03:43 PM
89934runr's Avatar
If you want to ditch the evap housing, I have a non-AC housing that should fit.
JEFF
Old Nov 18, 2007 | 03:57 PM
MMA_Alex's Avatar
or you can convert it to an air compressor...
Old Nov 18, 2007 | 04:03 PM
Targetnut's Avatar
there is an air duct/housing that goes where the evaporator is.
If you go to it you can probably get it all off in an hour or so.
Old Nov 18, 2007 | 04:14 PM
Yeah, I have the motor out right now so I figured it would be the easiest time to ditch the system. I don't know what the evap housing is, sorry. I am still learning.
Old Nov 18, 2007 | 04:27 PM
breknraj's Avatar
The evaporator housing is the piece of duct work under the passenger side dash that has the hose connections going through the firewall, and a radiator looking unit inside the duct.
A poster a couple up said that he had the non A/C duct available. That would replace the evaporator duct, keep your heat intact, and save you a little more weight, as well as prevent the radiator fins from getting plugged up by anything (and preventing airflow through it).
If the A/C is in working order, you could probably sell all the pieces to someone without, as a complete kit.
Old Nov 18, 2007 | 04:36 PM
OH ok, great. Thanks alot
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
BimmerSage
Sep 17, 2015 11:48 PM
Tacoma1313
Sep 8, 2015 01:27 PM
