Runs like crap after heavy rain
Old 10-18-2008, 09:07 AM
ricoman's Avatar
I have a '95 4runner with the 3VZE engine that runs like crap after a heavy rain. It will not rev past 2500 rpm or shift. After 10 min. it will dry out and run normal. I have changed the wires, distributor cap and rotor and seafoamed the engine with no improvement. What am I missing?
And yes, I did a search. The only thread I found was old, the last post was a couple of years ago and no one has responded to my post on that thread because it is buried so far back.
Thanks, in advance, for any help.
Old 10-18-2008, 01:15 PM
Matt16's Avatar
Did you remember the rubber O-ring on the distributer. That would be my first guess. Could it be the coil, or the igniter as both have high voltage I believe, I'm really well versed on the ignition system.
Basically, moisture and high voltage don't mix.
Old 10-18-2008, 02:20 PM
ricoman's Avatar
The distributor cap didn't come with an O-ring and the old one didn't have one so I didn't think it needed one. I'll try to find one, but I don't know where, I doubt the dealer will have just an O-ring.
Old 10-18-2008, 02:30 PM
Chapman88SR5's Avatar
Same thing happened to mine awhile back. Check for cracks around the intake system. Mine has a gap between the airflow meter (thing on top of the intake box) and the intake box. It has a bad gasket.
Old 10-18-2008, 03:12 PM
Marc's Avatar
Take a spray bottle full of water and start spraying stuff.
Make sure to spray the o2 sensors.
Old 10-18-2008, 05:33 PM
Matt16's Avatar
Good idea, this would be the best diagnostic strategy. I though the distributor had an O-ring, maybe I'm wrong.
Colington
03-08-2020 09:51 AM
the1998sr5
07-16-2015 06:20 AM
Kluch8651
07-09-2015 10:39 AM
Nickdigg
07-07-2015 06:04 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Runs like crap after heavy rain
