Running Rich and lack of power after HG replacement
Old 01-10-2009, 08:58 PM
PDX_1ton's Avatar
Hi all,
Sad sad day for me and the 22re. After replacing my HG I noticed a huge use of gas for the short distance I went. The truck seems to be running rich and lacks the power it had after the rebuild 200 miles ago. (Yes the head gasket failed on the rebuild that quick. The head bolts came loose.)
Here is what I did do after the HG replacement
I noticed a Code 5 and unplugged and repluged in the wire to the distributer cap. Rest EFI fuse and the code did not persist.
Then I saw a Code 6 (Ox Sensor) but decided to adjust everything first.
1. Warmed Engine
2. Jumped Te and E1 (Or what ever the number and letters are)
3. Set idle to 750 rpm
4. Set Timing to 5 BTDC
5. Set the TPS
6. Rechecked idle and Timing.
After adjustment no Codes were thrown.
What could be causing the truck to run rich and loose power?
Old 01-10-2009, 09:12 PM
scuba's Avatar
Next thing I would think would be 02 sensor...
btw, Can I see some pics of your truck, I used to have a truck exactly like it.. (see sig)
Old 01-10-2009, 09:17 PM
PDX_1ton's Avatar
Is there a way to test the O2 sensor. Some picts coming up.
Old 01-10-2009, 09:27 PM
scuba's Avatar
Yes, But your going to have to do some diggin in here to find the fsm for your year and the specs for the sensor..
https://www.yotatech.com/forums/f116...umbers-102344/
Sorry about that quick response, my old truck came to mind though...
Ouch much?
Old 01-10-2009, 10:10 PM
PDX_1ton's Avatar
Picts as promised. Pulling a 11,000 pound trailer from Oregon to St. Louis. Didn't know it weighed that much until we arrived.
Over heating as we crossed over Utah to Wyoming. I used a box fan and an inverter to cool down the engine. Took about 5 minutes to return to a normal temp.
Power washing out the truck before the trip.
Old 01-10-2009, 10:14 PM
Ezrider_92356's Avatar
that must have been a SLOW ride 11k behind an 22re hope you had good trailer breaks!
Old 01-10-2009, 10:16 PM
toyota4x4907's Avatar
I doubt he even got going fast enough to need trailer brakes
sweet little 2wd
Old 01-10-2009, 10:20 PM
scuba's Avatar
hah, wearing the same pants in both pics..?
Nice little truck though, I do miss mine...
I need to not drink
Old 01-10-2009, 10:21 PM
PDX_1ton's Avatar
I was thankful it was the 1-ton. Stock is beefy brakes. Going up hill was slow, but on the flats it was easy to keep 60-65 miles per hour. Just slow getting up to speed.
Scuba.. sorry about your truck. It is easy to get attached to them. Mine was given to me by my dad. He bought it new off the lot.
Old 01-10-2009, 10:24 PM
scuba's Avatar
In that situation the gears of the 1ton is where it counted, speed wise
Old 01-10-2009, 10:25 PM
scuba's Avatar
Oh oh, I spy a yota van (2nd gen sienna) in pic 2...
Can anyone tell im bored..?
Old 01-11-2009, 02:32 AM
the pics went showing up when i posted, that 11,000 lbs must have been gross combined vehicle weight? what did you have in that trailer? a load of lead?
in this pic i was at 14,500 gross - the 6800lbs my truck weights empty would be about a 7700lb load
i was at 21000 gross in this picture witch would make for an 14200lb load including the wave runner in the bed
the most i ever towed with the toyota was an 20ft trailer with an datsun 280zx on it without a motor or trans that i would guess was about an 4000lb load and it was all my truck could do to maintain 45 mph up an hill
Old 01-11-2009, 06:31 AM
PDX_1ton's Avatar
Yes the 11,000# was gross weight. Still very shocking.
Anybody else want to chime in on why I could be running rich?
Old 01-11-2009, 07:32 AM
874runnersr5's Avatar
best bet is the 02 sensor, when mine went it was brutal. It smelt sooo bad and ran like poop. Got a new one, wasnt much better but oh well. Then i did my timing chain, and acutally put the timing back where it was suppose to be and now it runs amazing...
Old 01-11-2009, 09:18 AM
sorry for getting off topic
i agree with the others about the 02 sensor could also be the tempature sensor
Old 01-11-2009, 10:42 AM
iamsuperbleeder's Avatar
you should have just zip-tied or bungied that thing to the front of the truck and carried on
Old 01-11-2009, 12:51 PM
desconhecido's Avatar
I love it. A $20 electric fan conversion.
Old 01-11-2009, 12:56 PM
that's probably what I would have done in that situation, lol, I don't like sitting around on the side of the road
but it only took him 5 mins to cool it down; it probably would have taken me 45 min just to set it up
Old 01-22-2009, 07:13 AM
PDX_1ton's Avatar
Thank you to everyone. Yes it was the O2 sensor. The old one was caked in a white powder. At first I didn't see any results. I pulled the EFI fuse for about 30 seconds to reset the computer. Upon the next start up she flew down the street. It actually was a bit shocking.
Old 01-22-2009, 07:16 AM
PDX_1ton's Avatar
Oh I thought about it, but the hood did not close far enough to see when driving.
87blyota
07-01-2015 05:26 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
newzingo
06-24-2015 01:50 PM
Quick Reply: Running Rich and lack of power after HG replacement
