rpms on hwy
rpms on hwy
hey there. what rpm do your trucks run at 60mph in 5th gear with the 3.0
i run at 2500 but the speedo is off like 2.5 miles per hour faster.
i was thinking 4.56 but speedo is off with 31s like 3 mph at 60 mph so im confused. looks like the last owner had a problem with the 3rd because there was diff oil caked on the 3rd, all over the gas tank and the bed when i bought the truck
awww.. 3.0 only?
sheesh
I run about 2500 with my 22re in 5th and about 2200 in 4th.
edit- got them backwards....
about 2500 in 4th and 2200 in 5th @ 60 MPH
sheesh
When I had my 3.0, I was always around 2500-3200. Cruising between 60-70 I was able to stay at around 2500-2800.
and if you are running 31's, like I was...I found I was about 10% off. So at 60 I was going 66 and so on. Factory speedo was set to the lower stock tire..even though the optional FACTORY package came with 31's. Always found that weird.
