Rough idle on 91 3.0
Old 04-21-2008, 08:09 PM
91YotaExcab's Avatar
The engine is running like crap up to about 2000 rpm and will still hesitate when past that when i hit the gas. i have replaced the plugs, wires, cap, rotor, both belt and the fuel filter. it has 97k miles and just started doin this a couple days ago... anyone got any thoughts that could help me out?
Old 04-21-2008, 08:13 PM
toytech76's Avatar
check your compression
Old 04-21-2008, 08:16 PM
keithdphan's Avatar
check timing
Old 04-21-2008, 08:20 PM
i should add that it onlys does this after it is warmed up when i first start it it doesent do it
Crawdad's Avatar
And if both of those are in check run some Seafoam through it, and some in the gas tank.
Old 04-21-2008, 08:24 PM
keithdphan's Avatar
check tps, then if its okay check timing.
Old 04-21-2008, 08:28 PM
how would i "check" the tps what would i be looking for if somehting is wrong with it and where could i find it?
Old 04-21-2008, 08:44 PM
keithdphan's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old 04-22-2008, 04:53 AM
toytech76's Avatar
your tps and timing arnt going to make it run rough after warming up. You probably have a tight valve. You need a comp test
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
montanatruck
02-26-2017 07:07 AM
Alex Bessinger
08-31-2015 09:17 AM
tomczaksdiesel
07-26-2015 10:35 PM
Quick Reply: Rough idle on 91 3.0
