Right or left head - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-17-2006, 05:13 AM   #1 (permalink)
ELD
Right or left head
Ok this might be a dumb ? But is there a difference between the right and left head on a 3.0? I noticed that one of the heads had a #1 and #5 in the combustion chamber side of the head. Does this mean that is for the right side of the engine? meaning #1 #3 #5 cylinders?
When I pulled the heads off, the head with the #1 and #5 was on the left side of the engine.
The #1 and #5 is cast in the head it's not just scribed on it.
'94 3.0
ELD is offline
Old 02-17-2006, 07:53 AM   #2 (permalink)
Elvota's Avatar
When I took my 3.0 heads off, I didn't see a difference, but I am by no means an expert. It seemed that even the exterior points for mounting accesories, etc, were matched. When they got all cleaned up, there was no way to tell the difference except for the fact that one of my heads had a broken bolt hole, which I knew was from the passenger side.
I believe the stamped numbers refer back to when the engine was manufactured. Something about the original tolerances and piston sizes. But I thought those numbers were stamped on the block, not head.
Elvota is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
P/S left....Manual to the right Bigblock 86-95 Trucks & 4Runners 5 01-29-2007 06:36 PM
does 22r head = 22re head imtxn 86-95 Trucks & 4Runners 16 12-11-2006 08:30 AM
Cracked Head or Blown Head Gasket? StevenR Maintenance & Repair Archives 5 06-14-2005 10:49 AM
left and right Localmotion 95.5-2004 Tacomas & 96-2002 4Runners 4 01-31-2005 11:53 AM
Replaced Head Gasket, but not Head Bolts -- How bad is this? The Rusty Gear 95.5-2004 Tacomas & 96-2002 4Runners 14 09-13-2004 08:03 AM
2009 InternetBrands, Inc.
