Reset ECM - Code 24 only one came back Where is the intake air sensor??
Old 08-12-2007, 11:10 AM
diverjeff200's Avatar
One more time...
Reset ECM codes. Only code 24 returned. Can't seem to find the intake air sensor.Running but just seems doggy.
Have looked over the FSM but can't seem to find what I'm looking for.
Safety & blue skies,
DJ
Old 08-12-2007, 11:14 AM
Staff
DeathCougar's Avatar
I believe they are refering to the air flow meter?
Old 08-12-2007, 12:21 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Yeah, there's a little probe down inside the VAF meter. You can see it through the flapper if you open it up. That's the intake air sensor. When testing the VAF meter, that's the little bugger you're testing against fluctuating temperatures (in the FSM). If it's not working right, you won't get the specified ohm readings. Meaning, well..you know.
zd92655
03-06-2022 12:58 PM
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
bigblue82
10
07-06-2015 08:27 AM
94hiluxZE
06-22-2015 10:42 AM
BTOWN4RUNNER
7
05-27-2002 07:00 AM
Quick Reply: Reset ECM - Code 24 only one came back Where is the intake air sensor??
