Replacing worn out leaf springs
Old 10-08-2008, 12:03 PM
jfly13's Avatar
I have the typical saggy butt on my 86 4runner. I have found for some reason finding replacement parts for my 4 runner than my 77 bronco. I don't want to lift it, just want to find some replacement leaf springs. Where is a good place to shop for them? Any suggestions on brands. It may see a little offroading in the future, but it is my DD for now. Thanks for the help.
Old 10-08-2008, 12:16 PM
934rnr's Avatar
jc whitney..
Old 10-08-2008, 02:04 PM
Junkers88's Avatar
This won't really answer your question but I just ordered a set of these and will be mounting them in the next couple of weeks. I'm doing it on a truck to gain 2" of lift and a little better ride as well as hauling capacity. Might be something for you to think about.
http://cgi.ebay.com/ebaymotors/NEW-R...mZ290014125492
Old 10-08-2008, 02:19 PM
highonpottery's Avatar
depends on how much you want to spend. do some research on the available leafs in the stock-ish height and you might find something up your alley. i went the more expensive route and got myself some OME Dakar leafs - which i love - and they give you about 2" more height and more hauling cap. i could have just as easily gone to the nearest junk yard and picked up some used ones, but those would prolly sag.
i got my OMEs from trdparts4u and the truck was my DD at the time, so I installed them on the weekend by myself and it only took 2hrs having never done anything like that before.
i think there needs to be a sticky on solutions to toyota butt sag. so many threads on this topic as well as that top gear video.
Old 10-08-2008, 02:32 PM
Toyvana's Avatar
If you're just looking to replace the springs, try DirToyBoy. He's a member here and sells used Toyota parts out of a Toyota truck junkyard in St. Louis.
DTB
Old 10-08-2008, 05:05 PM
874runnersr5's Avatar
im buying some downey 2" leafs, there was this one thread that showed a before and after. So youll get the idea of how much they lift it back up to stock height.
Old 10-08-2008, 07:41 PM
deserthound's Avatar
http://www.jcwhitney.com/ALLOY-STEEL...3427_10101.jcw
I just put a set of these on my 86. Rear sits back up where it belongs and the ride is better, especially over washboard roads. I also put in poly bushings. Bought the bushing kit from Autozone.
TURBOrunnerNM
07-22-2015 11:01 AM
cars-guy
07-11-2015 07:51 PM
garagespace
07-09-2015 08:37 AM
Nickdigg
07-07-2015 06:04 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Replacing worn out leaf springs
