| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
replacing upper ball joint
#2 (permalink) | |
Quote:
__________________
Brian 1998 4Runner SR5 Last edited by mastacox; 10-04-2006 at 02:20 PM. |
#3 (permalink) |
ok that sounds great. thanks!
#4 (permalink) |
if thats under pressure its gunna shoot out like a rocket man
#5 (permalink) | |
Quote:
One thing: you're gonna need a heckuva puller to get that BJ out of the spindle (I custom-modified a craftsman puller to work). Plan on it being a PITA, and a BFH probably won't do it...
__________________
Brian 1998 4Runner SR5 |
#6 (permalink) |
if its a spring its gunna be under ressure no matter what
#7 (permalink) |
Care to explain? The upper control arm will not be going anywhere if there is no load on it whatsoever.... i.e. resting on the bumpstops.... you know.... kinda what Mastacox said. Well exactly what he said to be precise.Welcome to Yotatech btw. You'll find lots o help here!! Cheers, Lee Hathaway
__________________
'93 4Runner, 31'' BFG Muds, K-N Drop-In, Custom 2.25'' Exhaust, Flowmaster 40 series, Deckplate Mod, No Sway-bars Mod, OME Steering Stabilizer, Ome M72F Frt Shocks, SDORI 2" B.J. Spacers, OME 901 H.D. Coils, OME N98 Rr Shocks Backroads Mapbook =$25.00 BFG Mudders =$450.00 1 Big bag of sunshine =$180.00 Staying on the trail for 5 days with your closest buddies all driving Toyota's =Priceless |
#8 (permalink) | |
Quote:
it works like a spring only in that it resists upward travel by twisting when the front suspension travels up after hitting a bump or something!, but when you allow the a-arm to drop any load that was once on the torsion bar is not gone because it does not have to resist the twisting motion of upward travel. so no there will be no load on thoes bars and youll be all good once you jack up your front end jeep boy!
__________________
95 runner 3.0 4x4 auto, ported/polished heads, downey headers, custom 2.5" downey exhaust all the way back, bored throttle body,HD tortion bars, 3" body lift, 3" drivetrain lift, BudBuilt low pro crossmember/ under belly skid plate,mile marker manual locking hubs,32x11.50x15 bfg a/t ko's, american eagle alloy 57 series wheels |
#9 (permalink) |
A couple of tips from having replaced all of my balljoints recently and previously put on BJ spacers:
Before you jack up the front, put a small metal or wood block between the upper arm and the bumpstop that it will go against. This will allow you to get the wheel off without jacking quite as high, and give you more room to work. To get the ball joint taper bolt out of the the steering knuckle, put some pressure on the taper bolt (with a bearing puller, tie-rod puller or pickle fork), then smack the cast portion of the knuckle that surrounds the taper bolt with a ballpeen or claw hammer (not too big) a couple of times. Your blow should be at a perpendicular to the bolt. This will loosen up the bond between the taper surfaces. With the load from the puller or fork, the ball joint will pop right out. HTH Last edited by 86Original; 10-05-2006 at 09:22 PM. Reason: Punctuation |
#10 (permalink) | |
Quote:
This is NOT a springloaded IFS but rather a rubber torsion. Pull your front tire and go have a looksie Just take off the tire, put the front end of the truck on jackstands, unbolt the shock, unbolt the four balljoint bolts and pull the BJ. Nothing is going to go anywhere even if you were to push the truck OFF of the jackstands or wail on it with an industrial jackhammer! And yes I know this for a fact as I personally unbolted the right front ball joint on my truck in this manner when I changed out my CV on that side.....
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 |
#11 (permalink) | |
Quote:
__________________
#12 (permalink) | |
Quote:
You may get a headache from it if you do. These bolts use 19mm nuts instead of 17 mm nuts, so they are substantially more stout. I tried. (Didn't get my 8lb maul out tho'.) What I was suggesting is just a more delicate method of accomplishing the same thing. I just used a bearing puller to put tension on the taper bolt, then just whacked it a couple of times with a claw hammer (NOT a sledge!!). If you use a sledge, you could damage the spindle! If you use a sledge, you'll need to just tap it. A ballpeen or claw doesn't have enough mass to damage the spindle.
#13 (permalink) |
Good advice and good to know!
![]() Is the lower ball joint just as tough to get off as well?
__________________
#14 (permalink) |
i had no prob with a pickle fork....i put it in, one good whack and it broke loose. had it all done and back together in about a half hour. thanks for the help guys
#15 (permalink) | |
Quote:
HTH |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Upper Ball Joint | TRDatVT | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 04-04-2007 05:35 AM |
| How to replace upper ball joint | Localmotion | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 02-04-2007 06:46 PM |
| New here and need help with upper ball joint | Stal | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 07-15-2006 08:12 AM |
| upper ball joint | Godzilla | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 07-08-2004 01:12 PM |
| upper ball joint removal... | acid_burn | Maintenance & Repair Archives | 4 | 12-30-2003 03:18 PM |
