replace dash and fuel light.
Old Jan 20, 2008 | 11:04 AM
woody88's Avatar
hey guys my ac controls no longer light up any more and im pretty sure i have an idiot light or low fuel light that doesn't light up either. My question is are these parts available at the dealer and fairly easy to replace? Also does a 93 pickup have a low fuel light it looks like it but not quite sure and i've run out of gas before and never seen one turn on so if there is one it's burned out.
Old Jan 20, 2008 | 10:22 PM
just a 22re's Avatar
if there is its right under the gas pic on the lower left (sr5) and to take it out easy one + screw on the vent side open door to get to in drop lower dash take all the screws out dont forget the two under the visor thingy (look at gauges then get close look up just over the tach and speedo) then pull out take the 4 + screews out of the cluster pull back about 3 inches slowly and reach around grabe the speedo cable and pinch it pull it out and your home free to install as same as taking it out now for the heater dohicky take a flat head now not a + and go from the sides and pop out the cover after tyou took the knobs off (just grab and pull) then youll see two +screws take them out and pull the heater control out wait no after you took the cover out you will see the lights take a 90 hook tool and pop them out easy as pie the gauge lights are ALL 194's and the heaters are the real tiny ones not sure of the number but autozone has them there real small look like 194's but like 1/4 of the size hope it helps!!
Old Jan 22, 2008 | 07:29 PM
woody88's Avatar
thanks i will be doing that this weekend
Old Jan 23, 2008 | 01:19 PM
dstn2bdoa's Avatar
would the #s be the same for an 88? i need to do the same.
Old Jan 23, 2008 | 02:47 PM
yeah i thinkthere the same all the way up to 08 but dont quote me on this as i dont care to drive a new car and get it all dented and dirty
Charecter1
Nov 6, 2023 10:08 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
bryan34w
Jul 6, 2015 05:53 PM
Jnkml
Jul 6, 2015 01:20 PM
