reed valve and cat theoretical question :p
Old 02-20-2009, 07:16 PM
needsomecam's Avatar
as you know on 3.o the reed valve draws air from the airbox and using the venturi effect of the exhaust rushing by raw air is drawn into the exhaust manifold on the passenger side so that it speeds up the catalytic reaction and thus performs better. Would you agree?
okay heres the question. Theoretically speaking if you were to not run a catalytic converter would you not benefit from having the reed valve?
Old 02-20-2009, 07:22 PM
toyota4x4907's Avatar
The 22re's does this as well
I don't see why you would need the PAIR system if you didn't have a cat.
Old 02-20-2009, 07:40 PM
abecedarian's Avatar
Well, Sin91's truck passed California HC and CO emissions with a hollow converter.
Seems the two systems compliment each other but are not mutually dependent.
And given that the PAIR system requires no horsepower to operate it, why remove it?
Old 02-20-2009, 07:53 PM
just contemplating and drawing conclusions of the melting pot of ideas and fathoms we call a toyota. lol but anyways would an engine benefit from having a cat. For example does it inrease gas mileage as well as reduce emissions? providing the engine has a proper amount of back pressure of course...
Old 02-21-2009, 06:30 AM
bump for abe or anyone else
coleypull15
11-03-2015 07:41 AM
tj884Rdlx
08-28-2015 12:04 PM
thefishguy77
07-30-2015 10:59 AM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: reed valve and cat theoretical question :p
