Rear window fun
Old Aug 22, 2009 | 10:04 AM
edeslaur's Avatar
Rear window fun
My rear window sometimes went up and sometimes doesn't.
Lately (I've had the truck a week), I haven't been able to get the "Rear Door" light to go out. Looking through the FSM's wiring diagram, I figured that out right quick. LOCK the door... deerrrr.
I had a FS Blazer, it was not nearly as anal about making sure the rear gate was closed. LOL
After that, it was still hit and miss.
The blue/black strip wire's relay-side connector was corroded, so I had to scrape that clean. The connector in the chassis-side looked fine.
After that, when I left the key on and twisted the relay 90 degrees, some of the relays in it click on and off. The connection was still not solid. Pulling/pushing the individual wires didn't help me narrow it down (but taking apart the relay and tracing the leads to the single relay clicking tracked down the wires I needed to pay attention to).
The ends of the connectors in the chassis side looke like they tend to connect with the spring-sides, not the broad flat sides, so I tweaked the ends of the connectors on the chassis connector to give them a slight bow at the front. Now the connection is decent and I can't make the relay click on and off.
BUT - what's the right way/better way to solve this?
Thanks!
Eric
Old Aug 22, 2009 | 11:44 AM
DeathCougar's Avatar
Sounds about like a good idea to me. You can also put some dielectric grease on the connector, which may help it take up just enough slack.
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
