rear spring swap question? sas 4runner
Old 10-12-2007, 07:15 PM
mrnick1979's Avatar
if i want to change from coils to rear leaf springs can i use the same housing? do they offer any weld on tabs or kits? i have a 79 solid front axle already and thought about swaping everything, but just thinking for now
Old 10-12-2007, 08:30 PM
Elvota's Avatar
You can use the same housing... just have to cut and grind all the link brackets off... which takes some time.
Marlin and All Pro sell axle perches, which will need to be welded on to capture the leaves when remounted.
A pickup axle of similar year would just bolt right in there, but you'd loose the option of changing the pinion angle which might be important depending on your lift.
Of course... you could mod the pickup axle perches... but now you just going to have to do a bunch of work again.
Old 10-12-2007, 08:36 PM
Sponsor
Tofer's Avatar
i just used a 92 pickup housing.....
Old 10-12-2007, 08:41 PM
Elvota's Avatar
Then you so cheated....
Old 10-13-2007, 05:55 AM
FredTJ's Avatar
Ahhhhh, why would you want to take a perfectly good suspension system and turn it into something from the dark ages
Fred
Old 10-13-2007, 06:08 AM
waskillywabbit's Avatar
If you want to swap out from coils to leafs just use the 1989-1995 Rear Lift Kit and get some shackle mounts too:
http://www.wabfab.org/products/suspe...earliftkit.htm
GreenLion
06-07-2021 10:49 AM
cchinny
06-25-2015 08:11 PM
Niameyrider
06-25-2015 05:50 AM
infinityisfive
06-16-2015 06:51 PM
Dave
7
06-24-2002 03:42 PM
Quick Reply: rear spring swap question? sas 4runner
