rear locker
Old 05-01-2007, 03:21 PM
dijlop's Avatar
rear locker
im lookin for a rear locker for my '94 2wd pu. its mainly on-road driving, so im looking for one that will run open until either it starts to slip and spin free or i flip a switch.
hows this one? http://www.drivetrainspecialists.com...-locker-1.html
Old 05-01-2007, 03:26 PM
bob200587's Avatar
Man, I'd say since it's just a 2wd get the Detroit tru trac limited slip. I don't see much point in a locker for a truck like yours. You could get an ARB, but still, the wheelin' potential isn't very high for your vehicle, at least not without alot of work.
Old 05-01-2007, 03:31 PM
dijlop's Avatar
u are quite persistent. maybe i should start dissin ur 4 cyl engine? lol
even ur sig is wacked. if the gates are never open, how can u recieve supplys? how about new technology? if we never tried something new, wouldnt that mean we would never advance? or do u think we should just be happy with cancer and aids still rampant and such?
anyways, i was looking for the detroit tru trac and this is what i ended up with.
Old 05-01-2007, 03:34 PM
dijlop's Avatar
whats the difference between the 7.5 in and the 7.5 in ifs?
through the ifs one i found a tru trac link, which showed me this.
http://www.drivetrainspecialists.com...ruetrac-1.html
Old 05-01-2007, 03:45 PM
dlbrunner's Avatar
You do not need to concern yourself with the 7.5 in diff. it is the front diff on a 4wd model.
You have a std 8" toyota differential. unless you swapped something else in there.
I think a LSD might be a better option being you drive a 2wd.
Old 05-01-2007, 03:49 PM
dijlop's Avatar
very helpful. thanks. i'll keep lookin. i tried to get a measurement, and ended up with the only ruler ive ever seen with no real measuring system. very weird. cant even explain it. lol
edit- found it. http://www.drivetrainspecialists.com...duct-2421.html
hows that price and such?
Old 05-01-2007, 04:05 PM
89-4Runner's Avatar
I got my locker (lockright - almost the same thing a lunchbox style locker) from CENTRAL4WD.COM and it was $239 w/free shipping...
Old 05-01-2007, 04:10 PM
dijlop's Avatar
found the one ur talking about and its for the v6 and turbo. i have neither, but nice find regardless.
found the arb locker for $912. lol. that sounds bout right. a bit too much $$$ for my tastes(taste being wallet)
Old 05-01-2007, 04:24 PM
Robert m's Avatar
everything i have read/heard is if you have a 1ton or a 4 speed trans you have an 8''
if you have anything else you have the 7.5
http://www.downeyoff-road.com/Chassi...ents/index.htm
Old 05-01-2007, 04:28 PM
dijlop's Avatar
oiy. lovely. umm. i guess its time to research more. lol. i'll check it all out in the manuals and such 2morrow, and worst comes to worst i'll find a real ruler and just see if i cant figure it out.
Old 05-01-2007, 04:34 PM
fthertime666's Avatar
2wd, 5 lug axles are a 7.5 inch ring gear, same as ifs front. The tru-trac should fit.
Old 05-01-2007, 04:39 PM
dijlop's Avatar
can i quote u on that one? kinda funny to me, cause i just quoted u asking if i could quote u...
Old 05-01-2007, 04:44 PM
ovrrdrive's Avatar
If you're planning on running bigger tires eventually you'd be better off to swap in a rear axle from a 4wd truck...
Not only is it stronger and geared better for your big tires (usually 4.10), but replacement and aftermarket parts are a dime a dozen. If you blow the 3rd in it you can get another stock unit for like $150 and you can buy just about any brand or type of locker or LSD you want to...
Old 05-01-2007, 04:50 PM
dijlop's Avatar
i dont plan on going over 30. probally closer to 29's.
the 4wd axles, pricing and install toughness?
Old 05-01-2007, 05:01 PM
um... yeah, you can qoute me the axle housing is completely different but the carrier and side gears are the same. AFAIK the actual R&P
gears are incompatible since the drive and coast would be on opposite sides.
Old 05-01-2007, 05:13 PM
MudHippy's Avatar
Here's the link that tells you how to determine for sure what type of axle you have. Your axle code will tell you with the most accuracy. Finding the information plate is simple, it's either in the door jamb or on the firewall behind the engine. If it (axle code) starts with an F, F###, it's a 7.5". If it starts with G, G###, it's an 8". The 5 lug thing is also true. However, the ring & pinion are actually identical with IFS. The same as with 8" gears being the same in fr/rr axles, so are the 7.5".
http://toyota.off-road.com/toyota/ar....jsp?id=274535
Old 05-01-2007, 05:20 PM
bob200587's Avatar
Wow, someobody's a little pissy tonight....I don't see how "dissin" my 4cyl engine would mean much, seeing as how you have the same motor. I also don't recall "dissin" you at all. You asked, and I gave you my advice. I don't think a auto locker would be a good choice, and an ARB is a little expensive, so I said, consider the Tru trac.
Not going to bother responding to the rest.
Old 05-01-2007, 05:38 PM
dont quote me!
hahahahlol sorry, guess I had my head backwards, confusedforgot front and rear drive shafts rotate in opposite deerections
Old 05-01-2007, 05:42 PM
91TPU's Avatar
i agree with this completely...in addition you say your gonna run 30inch tires, but trust me, when i feel as tho your gonna want more...thus the rear 4wd axle will do better for you...
Old 05-01-2007, 06:32 PM
Bunta Fujiwara's Avatar
If you really want LSD, you could swap in a '96-99 Tacoma rear diff, and go with 2WD for similar compound ratios. Don't know if it would bolt right up, but you could consider giving it a try. Again I apologize if somebody has already suggested this, because I only have one browser window open right now.
Quick Reply: rear locker
