rear disk setup off a hardbody??
Old 03-23-2009, 08:52 PM
MIKEMOKAS's Avatar
i was walking through the junkyard last week and glanced at a hardbody with rear disks... but dident get a chance to check it out because a friend needed help pulling something..
anyone ever look into this?
next time i go im going to check out....
axle shaft spline count...,
backing plate bolt pattern...,
and everything else, lines, mc, calipers...
thanks!
Old 03-23-2009, 09:20 PM
Staff
DeathCougar's Avatar
have never heard of such a swap, but check and let us know if its a viable swap
Old 03-23-2009, 09:23 PM
camo31_10.50's Avatar
ooo..that'd be the ...theres alot of Hardbody's at the local scrapyard...more than a few of the 4wd's have rear discs!!!!..please!.check and see!..
if they are interchangeable i doubt it would be worth the change...as they probably wouldnt give you THAT much more stopping power..might as well get a kit...lol
Old 03-24-2009, 05:37 AM
MIKEMOKAS's Avatar
ill definately check it out sometime this week! the nissan rearends are very similar to the toyotas arnet they? (3rd member setup and all...)
ill also need to check out the ebrake setup...
ttyl!
Old 03-24-2009, 02:40 PM
iamsuperbleeder's Avatar
and all Chevy 350's are the same
sounds like a good idea, since there tends to be a LOT more broken Nissan's in junk yards than Toyotas
if you can snag em for cheap, compare them side by side and see what kinda mods you'd have to make; it would be interesting to know
Old 03-24-2009, 02:46 PM
yoterr's Avatar
x12 lol very interesting, my drums are shot and rather spend the money doing this setup then on new brake drum parts
Old 04-02-2009, 06:50 AM
MIKEMOKAS's Avatar
the toyota backing plate bolt pattern is a square, and i think that the nissan bolt pattern is the same top and bottom, but its like 1in shorter front to back. and their would be no feasible ebrake. im going to check out some more options and reply later... still really want this swap.
ttyl!
oldirtydirt
02-23-2020 09:30 AM
jerusry
10-19-2015 05:28 PM
Bflo338
07-21-2015 07:28 AM
mtb_taco
07-15-2015 08:36 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: rear disk setup off a hardbody??
