Rear bolt in shock options
Old 12-03-2014, 09:37 AM
TRD_yota's Avatar
Do you guys happen to know what shocks fit in the stock location? I'm looking for something longer as my stockies do not allow for full droop of the rear. Wanted something cheap for now till I can the rear done up really nice. not trying to fab up anything since it would just be getting cut off later.
Thanks!
Old 12-03-2014, 09:38 AM
rattlewagon's Avatar
What are these shocks going on? Year/make/model? Going on a stock truck/runner?
Old 12-03-2014, 10:10 AM
TRD_yota's Avatar
1995 2wd with a SAS
TRD_yota's Avatar
its a Toyota pickup btw
Old 12-03-2014, 10:13 AM
Its its had a SAS then the rear must be lifted too, correct? So stock shocks wont fit.
Got any pictures of this truck?
Old 12-03-2014, 10:25 AM
TRD_yota's Avatar
no pictures. its using stock 4x4 leaves with a deaver mini pack. was looking at a factory location 10 inch stroke shock just don't know where to get one.
Old 12-03-2014, 11:00 AM
muddpigg's Avatar
limited droop is less of a concern than not enough up travel. If you've changed your rear spring set up then you need to measure the distance at full compression. To get more travel from a shock the rod and body both need to be increased in length, thus longer when fully compressed. Shock will be damaged if too long.
Simple solution for cheap and easy. measure at full compression then use and application catalog or email a shock manufacture length with mounting config. I was at one time planning on running monroe shocks that was a full size dodge application.
the1998sr5
15
07-14-2020 08:35 PM
msane99
07-17-2015 10:13 AM
Iceman4193
07-15-2015 04:48 PM
Nickdigg
07-07-2015 06:04 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Rear bolt in shock options
