Randomly won't start this morning (VIDEO)
Old 09-05-2013, 11:48 AM
tumor21's Avatar
Getting power from battery to all other toys on truck. Have a separate switch for stereo, which works. pulled ignition switch and tried it manually (always fun to remind myself how easy it is to start one of our trucks with nothing but a phillips head screwdriver) ...nothing. Bad ignition switch maybe? If so, how much of a pain is it to replace one of these? Also, have never needed the clutch in to start.
Old 09-07-2013, 08:48 AM
YotaSnap's Avatar
One thing I've seen a problem with is the wire to the starter popping off.
Also are you hearing the starter relay kick in?
Does your battery have enough juice to turn the starter?
Old 09-09-2013, 11:23 AM
tumor21's Avatar
Problem with lead to the batt yet ironically stereo and anything else had wired to batt worked perfectly. Tightened down positive lead and she started right away. Good thing it was something stupid. Might consider better batt cables.
Old 09-09-2013, 01:37 PM
recowl105's Avatar
Can you hear a click outside the truck when you try it? i had an 88 Toyota with a bad starter that would randomly not start for 4-5 hours at the most odd times.
Charecter1
11-06-2023 10:08 AM
TURBOrunnerNM
07-22-2015 11:01 AM
karbin
07-05-2015 11:37 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Randomly won't start this morning (VIDEO)
