Radiator boiling
Old 09-01-2009, 03:51 PM
4runner92's Avatar
Radiator boiling
I drive my 4runner daily with no problems but once a week I drive it about 15 miles on the freeway and when I get there it's always boiling in the overflow and the radiator. New thermostat and new waterpump last month and the gauge isn't reading hot any idea what's wrong?
Old 09-01-2009, 05:32 PM
mr toytech's Avatar
sounds like an air pocket in the cooling system. or needs a new radiator cap.
Old 09-01-2009, 05:40 PM
yoterr's Avatar
yeah, the only way to get air out of the system is to park the truck with the front end elevated and to start it with the rad cap off and let it warm up to operating temp and add water once it gets done bubbling...
Old 09-02-2009, 03:22 AM
TNRabbit's Avatar
Could be air, but sounds more like clogged radiator.
Old 09-02-2009, 04:24 AM
baseballchamp157's Avatar
if it aint clogged. and you do as yoterr says and that dont help. i believe you got yourself an exhaust to coolant leak. cause thats what i had in my 3.0 and it kept over heating.
Old 09-02-2009, 08:46 AM
sb5walker's Avatar
"Boiling" in the overflow sounds like air being forced out of the top of the rad, and that could be exhaust gas going through a leaky head gasket. Recommend compression test, and leakdown test if necessary. Watch #s 6 & 1.
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
mreagen
10-05-2015 04:27 PM
scott90
10-04-2015 09:21 AM
Matthew Perez
09-28-2015 05:43 PM
Quick Reply: Radiator boiling
