Question about high output Alternators. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-19-2007, 07:04 PM   #1 (permalink)
jagger_snitt's Avatar
I'm in need of a new alternator,thought process says upgrade while your at it.
The local Toyota Guru at a local shop says he doesn't/hasn't had good luck with them,but said he does like and sell the stock ones?
What do you guys think and where/which alternator would you get?
__________________
"The Black Death" (DD)1988 4Runner 22RE 5Spd,StreetRvHead,261c Crawler cam,hi-output alt,35" BFG MTs,Optima Red Top. SAW 25mm T Bars,4Crawler BJ spacers,Tuff country 3" add-a-leaves,4.88 gears.Need 7.5 4.88 gears/thirdmember! PM ME!!!
"The Silver Death"1987 4Runner SR5,22RE 5spd,4Crawler Short Throw Shifters T-cases and 5Spd,SAS,MC Dual cases,4.88s and detroits front and rear,Allpro Tripple-X transfer case mt w/drivetrain E-brake,TG rock sliders,3"susp,3"body.35" Maxxis Big Horn MTs
jagger_snitt is offline
Old 08-19-2007, 07:53 PM   #2 (permalink)
i went with the stock. it might be worth it with the winch, or if you had a big stereo, etc.
MMA_Alex is offline
Old 08-19-2007, 08:07 PM   #3 (permalink)
colsoncj's Avatar
Send a message via AIM to colsoncj
been several times ive wished i had one larger than stock, and in 40K miles im on my 3rd stock one....
dont know where to get a better one, i figured on waiting til i swap a 302 and deal with it then.
__________________
Cory
Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here
04 Dodge 2500 Cummins - DD/Tow Rig
02 Z06 Corvette - Weekender
94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727
72 Buick GS - i.e. the project that will never get done.
colsoncj is offline
Old 08-20-2007, 05:23 AM   #4 (permalink)
Thanks guys,wow 3rd one! I've found a few places to to buy some but I just was curious to everyone's luck with them. I don't want to spend $300 on a Hi - output alternator that just lasts 40k.
__________________
Old 08-20-2007, 06:51 AM   #5 (permalink)
tulsa_97SR5's Avatar
I think it'd be ideal to find another toyota alt that could be used without too much custom bracket work. Searching around the other day it looks like newer camry's have 100amp alt's, highlanders use 100 or 120 amp units, the tundra's and sequoia's even bigger. The camry unit is interesting to me just because there have to be a friggin ton of them out there, found a bunch for $50 on car-part.com. I guess I should just get one and see how different the size, mounting, wiring all are.
__________________
Brian
85 sr5, 5spd - back on the road, doing DD duty for now
86 2wd reg cab - future project
90 sr5, 97 - gone
tulsa_97SR5 is offline
Old 08-20-2007, 06:54 AM   #6 (permalink)
Pest's Avatar
Quote:
I think he meant it's his 3rd Stock Alternator, and that he was wishing he'd gone with the high output.
__________________
-Pest (Nate)
1985 4Runner
278,xxx miles and still young!
2" lift.
32" x 11.50" BFG A/T's on 15" American Racing Wheels.
Aussie Locker in the rear
Commando Car Alarm with Power Locks and Remote Keyless Entry
Rewired power windows to run with ignition off.
LCEngineering Header, Magnaflow Muffler, 2.25" Exhaust
Rock Crawling puts the FUN in Funeral.
Pest is offline
Old 08-20-2007, 06:58 AM   #7 (permalink)
ewong's Avatar
There are are few options
If you have a NON AC motor - get the alt from an AC one
22RE I think that bumps ya from 40amp to 60amp
Then there is the MR2 swap - I think that nets ya 80amp?
THen you can get
a rewound alt in a stock case
a GM case adapted to 22RE
HiPo NipponDneso Alt (OEM)
Im running a $$ 130amp NipponDenso alt...
wrangler power products
ewong is offline
Old 08-20-2007, 07:03 AM   #8 (permalink)
tc
tc's Avatar
Send yours to Boyle Future Tech in California to be rebuilt.
Molly and I have both had ours done, and they are AWESOME. For $118 including return shipping, they upgraded mine to like 140A, making 60A at idle (which is more important for our trucks)
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 08-20-2007, 07:09 AM   #9 (permalink)
Thanks Tc and Ewong that is what I needed to know.
Hey Tc do you have any contact info for Boyle Future Tech?
Thanks again!
__________________
Old 08-20-2007, 07:17 AM   #10 (permalink)
colsoncj's Avatar
Quote:
Yes, I meant im on my 3rd stock one... 1 of them died from overstressing is my assumption, the other 2 died from bearing failure. Whenever I address this, I'm going to mount it up as high as possible, I think muddy water killed one of them.
And I do wish I had a higher output.
__________________
Cory
colsoncj is offline
Old 08-20-2007, 07:20 AM   #11 (permalink)
ewong's Avatar
The problem with most "hipo" alternators is the same problem with HiPo motors..
The items sell on "Peak HP" or int he case of alternators - 200amps!!!!
BUT the reality is 200amps do you no good is the alternator only puts out 200amps when the MOTOR is spinning at 5600rpm...
So - what you need is a DECENT idle performacne and amps at say 2500rpm on the motor (fast idle to rcharge the batt when winching)...
That can be done but its expensive (I think is more windings with a thinner wire = more copper = more labor to wind = more $$$ )
TANSTAAFL
ewong is offline
Old 08-20-2007, 08:50 AM   #12 (permalink)
tc
tc's Avatar
Boyle Future Technology
12325 Locksley Lane, Auburn, CA 95602
phone: (530) 888-6290
ewong - Boyle will build it however you ask him for the same price. He had to try a few different setups to see what was best for mine. They provide a "cert" showing the output at various RPM's
__________________
tc is offline
Old 08-20-2007, 09:27 AM   #13 (permalink)
wardriver's Avatar
Something tells me he is about to get a flood of calls about reworking a stock Toyota alternators.
__________________
Current Toyota
-95' 4Runner - 3.0/AT - New HG - Yakima Rack - MT's - Hella's - GPS- Sat Radio - Onboard 120V
Former Toyotas - 81' Trekker- 70' FJ40 - 76' FJ40 -72 FJ40 - 85 Hilux (ZERO options)
Staff Mod for nHunting.com a community forum for hunting/fishing/shooting
wardriver is offline
Old 08-20-2007, 09:38 AM   #14 (permalink)
Ringmaster's Avatar
Quote:
No doubt!
__________________
99 4Runner, 3.4, 5 spd., Manually shifted E-Locker, 4:30 gears, 285/75/16 MTR's, Airbox mod through the bottom of the inner fender.
Ringmaster is offline
Old 08-20-2007, 09:55 AM   #15 (permalink)
ewong's Avatar
Sorry - I didnt mean to imply that Boyle was not reputable...
I was responding to the OP's comment that the Yota Tech calims to not have had god luck with hipo rebuilds.
Like anything else - you tend to get what you pay for.
ewong is offline
Old 08-20-2007, 10:45 AM   #16 (permalink)
gixxerjesse's Avatar
Send a message via AIM to gixxerjesse Send a message via Yahoo to gixxerjesse
i think he tends to stay fairly busy his name is out there as one of the best places to go and so far i have not found any bad reveiws about him. and if anyone has seen TC's truck in person you will be able to figure he needs alot of juice on the trails esspicially with those light force lights, basicly the power of 2 suns on the front of the truck.
__________________
it cost the US mint 1.7 cents to to create a penny, so a penny for your thoughts costs the government almosts 2
gixxerjesse is offline
Old 08-20-2007, 03:38 PM   #17 (permalink)
tc
tc's Avatar
Actually, the 8 - 55W rock lights are what necessitated the need for the upgraded alternator after the truck died coming down Moab Rim ....
__________________
tc is offline
Old 08-21-2007, 07:51 AM   #18 (permalink)
Thanks TC
__________________
Old 08-21-2007, 09:11 AM   #19 (permalink)
TNRabbit's Avatar
I used Boyle for the 135 amp upgrade to my stock Yota alternator and LOVE IT! It came back looking brand new and works great!
__________________
TNRabbit
Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap
3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/
Quote:
Originally Posted by Junkers88 View Post
Like the good book says "you can give a man a Toyota and he will wheel for a year, you can teach a man Toyota and he will wheel for a lifetime."
yotatech 3:16
TNRabbit is offline
Old 08-21-2007, 11:20 AM   #20 (permalink)
all i am saying is when you turned the light forces on in the middle of the trail at night when i wasn't thinking about it i got spots on my eyes for a while
__________________
Old 08-21-2007, 12:06 PM   #21 (permalink)
olharleyman's Avatar
Has anyone heard of ACE ALTERNATORS they have a 160 amp and they tell me it puts out 70 at idle and at 1200 it is full on 160. Comes with a 1 year warrenty and it 155.00 bucks shipped from coast to coast (cali to maryland)
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
88 stock 4runner
3.0 auto
for now
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 08-21-2007, 03:33 PM   #22 (permalink)
tc
tc's Avatar
Quote:
Yeah, a million candlepower each will do that LOL
__________________
tc is offline
Old 08-21-2007, 05:37 PM   #23 (permalink)
homewrecka's Avatar
Does Boyle have a website? I did a search and it came out unsuccesful. More info please. Thank you.
Mike
__________________
Mike
Aiea, Hawaii
1989 Toyota 4Runner
4 Inch Pro Comp Suspension Lift
33 x 12.5 Pro Comp Mud Terrains
15 x 10 Inch American Racing 589 Rims
For now...
homewrecka is offline
Old 08-21-2007, 05:48 PM   #24 (permalink)
homewrecka's Avatar
Cool
In the past, I ordered a hi amp alternator from Mr. Alternator. The alternator was 150 amps and the price was not that outrageous. I needed the alternator for my CB radio setup. The alternator held up very well! The only thing was that the plug for the alternator was badly worn and didn't charge up after awhile. Soooo, I took out the alternator and put in a stock alternator and when it did not charge up, I realized then that it was the wire/ plug and so the 150 went back in.
Mechanical Man is another place that I have heard of. Their alternators have a 'hot' rating as other companies rate their products 'cold'
Just my 2 cents...
Mike
__________________
Mike
Aiea, Hawaii
1989 Toyota 4Runner
For now...
Old 08-21-2007, 07:26 PM   #25 (permalink)
Jerm's Avatar
http://toyota.off-road.com/toyota/ar....jsp?id=186492
http://www.yotatech.com/f116/stronge...rnator-100839/
Those links were helpful for me.
__________________
Just my thought.
96 4runner SR5, 3.4, Auto, B&M trans cooler, H4 H.I.D. conversion
Sway-A-Way/O.M.E.
Jerm is offline
Tags
136, 160, alternator, alternators, amp, fj40, high, ii, mark, nippondenso, output, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
HIGH OUTPUT ALTERNATOR, any problem if runin too high voltage?? Chief_Yota 86-95 Trucks & 4Runners 10 08-04-2007 11:55 PM
High Output Alternators - Question About wiring LUV24BY 84-85 Trucks & 4Runners 16 06-14-2007 09:59 AM
How to test a high output alternator Bumpin' Yota 86-95 Trucks & 4Runners 3 03-21-2006 10:38 AM
New Alternator... High output... Ducky 95.5-2004 Tacomas & 96-2002 4Runners 8 12-22-2004 07:05 PM
High output alternators george16 95.5-2004 Tacomas & 96-2002 4Runners 18 03-24-2004 09:13 PM
2009 InternetBrands, Inc.
