Question about 80a AM1 GLOW
Old 02-26-2011, 04:14 PM
wvprankster's Avatar
I was doing some work on the fuse box under the hood of my 89 4Runner and got the bright idea to try to pull the 80a main fuse. As I soon learned, it doesn't pull out (it's supposed to push out the bottom). In my efforts, I broke a lot of the black plastic casing around the 80a fuse.
So now the filament is exposed (covered of course by the cover of the fuse box).
My questions are:
1. Can I just leave it alone in its exposed condition?
2. If not, do I need to replace it? or
3. Is there some way to protect it short of replacing the whole thing?
4. If I have to replace it, how do I get access to the underside of it?
Thanks,
Derek
Old 02-26-2011, 04:17 PM
rworegon's Avatar
Replace it.... try a quick search here as this has been covered many times.
Old 02-26-2011, 04:23 PM
looked around a bit
didn't see anything -- guess this newb needs to work his search skills.
Thanks,
Derek
Old 02-26-2011, 04:29 PM
this thread seems to
tell me what I need. https://www.yotatech.com/forums/f116.../#post51575035
Old 02-26-2011, 04:41 PM
rworegon's Avatar
Originally Posted by wvprankster
Good work...now go fix it!
You can pick up that fuse at the local auto parts store....no need to go to Toyota for it.
Old 02-26-2011, 04:52 PM
xxxtreme22r's Avatar
Replacing the fuse is easy, but replacing the fusible link has been up for debate many times as to what you should use. Whether it be a real fusible link wire or a 6-8 gauge wire. But if you replace it with regular wire make sure it's at least an 8ga preferably a 6 ga wire. But this is only my opinion.
lectric80
08-11-2015 12:02 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
4Runnin2000
07-29-2015 06:09 PM
Quick Reply: Question about 80a AM1 GLOW
