PS fluid put in my PS Pump instead of ATF!
Old 06-18-2008, 09:13 AM
dafried's Avatar
Hello All,
I loaned my 4Runner to a neighbor for a week. He was going to northern AZ with family and pulling a boat.
He thought he was doing me a favor and added PS fluid to my PS pump when he checked out the fluids before coming back home.
What now? I have a noise, but steering works.
Thanks in advance
Old 06-18-2008, 09:22 AM
Red_Chili's Avatar
If he put NAPA PS fluid in there, no worries. If he put a cheapie in there, take a hose off your steering box (after putting some pan and drip catcher underneath, makes a MESS) and drain the dang thing. Reassemble, refill with ATF, jack up the front end, and with the motor off cycle the steering lock to lock about 50-100 times. Add more fluid as needed. Now repeat with the engine running.
Now repeat the ordeal. Should be good.
Old 06-18-2008, 04:38 PM
Junkers88's Avatar
I'm SO glad to hear that. I didn't know I needed ATF in mine and topped it off with NAPA PS fluid.
Old 06-18-2008, 04:55 PM
1992toyota4x4's Avatar
do all toyota trucks need aft instead of ps fluid in the ps pump?
Old 06-18-2008, 05:37 PM
86tuning's Avatar
All Toyota vehicles use Dexron type ATF in the power steering systems. Dexron 3 is the fluid you'd get from a Toyota dealership. But basically any ATF will work just fine.
Old 06-18-2008, 05:38 PM
rdlsz24's Avatar
Your friend must have not read the ps reservoir cap lol.
Rob
Old 06-18-2008, 05:43 PM
abecedarian's Avatar
at least you didn't get ps fluid in the tranny.
Old 06-18-2008, 06:52 PM
anotherjeff's Avatar
I don't get it... Is there something special about NAPA PS Fluid?
Old 06-18-2008, 07:08 PM
just a 22re's Avatar
i use power steering fliud in mine i dont use atf and i have had mine for 3 years now and no nose at all and i used the chepo stuff
Old 06-18-2008, 07:23 PM
stupid_mud_gremlins's Avatar
I use everythi9ng from 10w30 to 80W90 in mine...whatever's handy. Leaks like a sieve and needs to be replaced anyway.....
Old 06-18-2008, 09:47 PM
shansethp's Avatar
what happens if you use power steering fluid, generic stuff?
Old 06-19-2008, 02:17 AM
Targetnut's Avatar
there is nothing wrong with using P/S fluid for your P/S
Unless you have one of those fruity German cars that have some "special" fluid
Old 06-19-2008, 02:24 AM
shansethp's Avatar
okay then what are they talking about by putting in ATF in place of the PS fluid??
Old 06-19-2008, 05:07 AM
Red_Chili's Avatar
Based on local dealer experience. Yeah, it is pretty good stuff. Still better to use what the factory recommends.
Using the generic stuff in my young ignorant days resulted in massive leaks in short order.
Old 06-19-2008, 05:08 AM
Red_Chili's Avatar
ATF is factory recommended.
Old 06-19-2008, 07:01 AM
T-1000's Avatar
ATF is recommended, but it's all basically hydraulic fluid. It won't hurt anything.
Old 06-19-2008, 07:38 AM
tc
tc's Avatar
Too many threads to quote ...
My experience has been the same as RedChili - using power steering fluid instead of ATF has resulted in leaks and blown power steering pumps (yes plural) in short order.
I also x2 the purge procedure he listed, but I wouldn't be super anal about getting every drop out of there. Get most of it out and dilution will be your friend in this case.
Old 06-19-2008, 08:11 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
I think there's a problem with mixing the two, though.
ATF has conditioners where as PSF does not. This may explain any issues. I've always just ATF. It's cheaper, anyway.
Oh, I have read that PSF was thicker and would cause too much pressure for systems not designed for it. Don't know how true it is. You read so many things.
Old 06-19-2008, 08:49 AM
rdlsz24's Avatar
If you look at them you can tell that PS fluid is thicker. ATF is like red water.
Rob
Old 06-19-2008, 10:20 AM
js9924's Avatar
ive known many people who have put ps fluid just because it is called a ps pump. Even though it says in the manual and the cap to use atf. People are so stupid, they think that they know everything about something when they really dont have a clue.
Like last week my gf's mom says there is no oil on her dipstick so I tell her only put in 2 quarts and then check it again and fill to the mark. Of course she doesnt listen and thinks it is completely empty and puts in a whole gallon of oil. Now she wonders why the oil pressure is high and she has oil everywhere inside the engine compartment. She is just lucky it didnt leak into the cat and ignite.
Quick Reply: PS fluid put in my PS Pump instead of ATF!
