Problem: Hard to shift gears.
#62
so what do you mean exactly when you say ''its wet under my clutch"? inside the truck, under the truck, dripping down the bell housing? can you shoot a pic of it? from what you are saying it could be the slave cylinder or maybe just a loose line fitting at the slave... or if its wet under the carpet that means the slave master is bad...
#64
have you thought about doing a budget long travel on your truck? I did it on mine, it's pretty sweet, check out my build thread..... https://www.yotatech.com/forums/f199...thread-196764/
#66
yeah. u need to find out if that is brake fluid from the clutch master reservoir. Is it low? its located next to the Brake master cylinder/booster. has a cap on it. is it low or wet around the sides up against the firewall? from the pic i would say yes... 99% sure its the slave master cylinder. go to autozone. if i remember correctly it costs around 20 bucks...easy to put in
#67
I will check this all tommorow it's 10 and I have to wake for class at 5:30. But thanks for all the help I'll let you know tommorow. And that long travel seems good but I'm only 18 and have a limited to nothing budget. Ha but thank you so much.
#70
yea that's the reservoir make sure thats full there is also an adjustment under the clutch pedal make sure it has around eh close or a lil less than an inch of play before you feel pressure from pushing in the clutch. also this happened a few months back but over a two day period it was hard to shift then just not being able to push clutch in at all pedal went straight to floor my slave cylinder that is bolted to your tranny my two bolts stripped out from when i had my clutch replaced make sure that didnt happen to you as well!!
#71
i was going to say judging my the rust and corrosion on the clutch master i was going to say looks like its been leaking for a while but then again it might just be from your roads!!!. im in Florida no rusting here (thank God!!!!)
