POWERLESS when cold
Old Jan 19, 2007 | 09:57 PM
LS1Steve's Avatar
POWERLESS when cold
I know most small engines are, but it has gotten worse lately. The thing strains hard when cold and even after the guage shows normal op temp, it takes a good 20min before power returns to normal. I'd swear it gets back to normal faster if I happen to turn it off (like after a short trip) then back on only 10min after cold startup. This is all much more drastic lately. The truck is in perfect tune and has new plugs/cap/rotor. Almost feels like the valve near the MAF that stays shut for warmup is sticking closed after its up to temp (???) mileage has gone to shhh too
Old Jan 20, 2007 | 07:41 AM
tc's Avatar
tc
Mine would do that, seems to have gotten better since I replaced the O2 sensor. I had a CEL, but was too lazy to read the code...
Old Jan 20, 2007 | 09:49 AM
LS1Steve's Avatar
I have never had a CEL
Old Jan 20, 2007 | 01:10 PM
enoc's Avatar
catalytic converter?
Old Jan 20, 2007 | 02:48 PM
Mudlover's Avatar
No power when cold
I am having the same problem rigth now. If I let it run for 5-10 minutes, it is fine. But if I just jump in, start it and go, a snail would out run me.
The check engine light is on, I just need to pull the code. Any thoughts??
Old Jan 21, 2007 | 08:32 AM
tc's Avatar
tc
Pull the code and look it up:
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
Old Jan 21, 2007 | 04:11 PM
BUNYKLR's Avatar
I always warm my engine up for a minimum of 10 minutes before I go anywhere when it's cold. Summer I go 5 minutes. Old habits from the Hummin Cummins days.
kawazx636
Oct 6, 2021 03:03 PM
Kylenicoll33
Dec 10, 2015 06:43 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Ditch Doc
Oct 27, 2015 03:20 PM
bryan34w
12
Sep 30, 2015 02:50 PM
