power steering fluid leak
Old 06-30-2007, 01:06 PM
directlink's Avatar
Power steering fluid leaks out of the driver side of my truck (1990 sr5 4x4 3vze) I first noticed this about a month ago because it left about a 2 foot wide puddle in about a day. I filled up the reservoir with new "leak stopping" power steering fluid and it went away until about two days ago. Now it just drips out very slowly. I think there is a bad seal but can't tell. If anyone could show me how to look for that I would appreciate it. Also is there any alternative to replacing the seal? I heard i can be heard to do. Thanks.
Old 07-03-2007, 06:56 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Hey! Sorry no one has responded at all. It could be a bad seal or it could something else, but not much. What I mean is do a search on power steering pump/leak and there are threads answering your questions.
I had a leak for a long time. Turned out it was only a loose bolt on the pump body. Leak gone.
Old 07-03-2007, 07:40 PM
mtnfreak's Avatar
Check the hose clamps on everything related to the PS system. There's a good chance that they've loosened over the years. Then clean everything and re-examine frequently. Hopefully you'll be able to tell where the leak is coming from if the clamps weren't the issue. Also, check your owners manual for the correct type of fluid for your vehicle. Using the wrong fluid can cause leaks as well.
Old 07-03-2007, 07:42 PM
Kaleb's Avatar
Right after I did a SAS I got a power steering leak. The leak was coming out of a bolt right on the top of the steering box. All I did was tighten that down and taa daa it was fixed.
Old 07-04-2007, 01:50 PM
Alex 400's Avatar
I had a problem with mine leaking a couple months ago. It turns out the rear seal blew out in the pump and I bought a reman pump from a auto parts store. Works great. no more leaks.
Old 07-04-2007, 04:14 PM
navyredneck's Avatar
Mine was leaking. I bought some high mileage ATF (has seal conditioners in it). I flushed the power steering system, refilled it with the same ATF, and it stopped the leak (and noise).
Old 10-20-2007, 06:56 PM
fredtheturd's Avatar
I kept blowing seals on the gearbox input shaft (where steering wheel hooks up) went through 3 gearboxes & decided to shell out the $400 to Allpro Offroad for the lifetime gearbox. Been leak-free for 3 years running....at least from the gearbox
Old 10-20-2007, 09:10 PM
86tuning's Avatar
wash it off first, then run the truck, have somebody turn the steering wheel to increase pump pressure, then look for the leak...
won't be hard to find
jasonty
41
12-23-2018 01:00 PM
the1998sr5
07-16-2015 06:20 AM
voiddweller
07-15-2015 03:56 PM
Rkellerman
07-12-2015 08:42 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: power steering fluid leak
