Post Head gasket job, now scraching my head
Old 08-06-2009, 04:14 PM
mac9968's Avatar
All went well with replacing the head gaskets, engine in all back together. I am attempting to get it running, and it turns over strongly then acts like the battery is dead. Next attempt I hear just the starter "click" wait a few minutes( like battery rebuiding) and it will spin good and then stop. The battery has tested good, and was replaced. I am wondering if the wiring harness has is grounded or has a dead short, any suggestions?
Old 08-06-2009, 07:24 PM
nobrainsd's Avatar
Not a lot of things related to a HG change that would effect your starter. I did have this issue after changing my HG. The starter turned over and the truck ran, I stopped and tried to start again. The started engaged then stopped. Subsequent attempts just got me a click. I checked the ground connections, checked the battery cables and was stumped. My starter had chosen that odd moment to fail. Don't overlook the obvious? I checked the voltages to the solenoid and the starter motor. I pulled the starter (a pain). Hit it directly with the battery. Click and nothing. Replaced the starter and that was it. Have you done any other work other than a the headgasket? It may be nothing more than a bad starter.
Old 08-06-2009, 07:35 PM
Plumbrbob's Avatar
I am with nobrainsd go with the obvoius the auto shops around my neck of the woods will even bench test starters if you need. In my exp. i always have an unrealted problem crop up after a big job usually caused by my fat body and limbs crushing something or pulling on something or cracking somethng.
good luck
Old 08-07-2009, 07:48 AM
mac9968's Avatar
Thanks Plumbrbob, after poking some more, the starter is acting very suspect. Now I believe I am looking at a timing issue. Thanks for the reply.. new to yotatech.. but I like it
Old 08-07-2009, 07:51 AM
mac9968's Avatar
thanks nobrainsd, you are right on, I now do believe I am looking at a starter issue, couple that with timing issues
Old 08-08-2009, 08:44 AM
mac9968's Avatar
Just checking back in, it was a loose Pos on the starter. I am now turning over nicely, but running poorly... next step... Diag codes
Old 08-08-2009, 08:54 AM
Plumbrbob's Avatar
lol thats funny after I did some work on my truck my engine on start up was making a crazy thwacking sound i thought something horrible was wrong. then a few days later my starter fell out LOL.
Old 08-08-2009, 09:25 AM
yoterr's Avatar
LMAO^^ ive done something like that...i left the ratchet on the crankshaft pull b4, then started motor then heard the ratchet fall of with the bolt good stuff
Old 08-08-2009, 09:30 AM
iamsuperbleeder's Avatar
at least all it did was fall off
I had the hood off my Isuzu Pickup the first time I fired up the motor I rebuilt in it, and I did the same thing and left a 1/2" drive socket and 12"breaker bar on it, and the motor started, jumped around like crazy for a second or two at 2k RPMs because of the off-balance, and then launched the freek'n breaker bar and socket about 100ft into the air and came down about a foot to the right of the truck!
scared the bejesus outta me, lol
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
smiley52
07-11-2015 05:16 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Post Head gasket job, now scraching my head
