POLL: Who wants 22RE over 3VZE? Count me in!
Old 05-17-2004, 08:17 PM
Forerunner's Avatar
Question POLL: Who wants 22RE over 3VZE? Count me in!
Well, I could probably go on about it for hours.. I will try to be brief. I used to have a 4Runner with 22RE 4cyl and a standard. I now have a 3 VZE v6 automatic. After owning it and working on it for a while, there is just about nothing about this engine that I like. I want 22RE back.
Transmission choices aside, who else would prefer 22RE over 3VZE? Feel free to post with or without listing your reasons, but reasons would make it more interesting. Some of my reasons are
3VZE is a pain to work on
3VZE eats more gas than a V8, even when properly tuned, while providing power output of a 4 cyl
22RE is considerably better on gas under the same conditions
3VZE is hardly more powerful than 22RE, regardless of what the specs say, even though it is a V6
It is ugly and takes up the entire engine compartment, making accessing anything impossible - with all the stuff that they packed in that engine, you would think it would be better in some way?
Towing with 3VZE is only marginally, if at all, different from towing with 22RE
So much for being brief So, what's your pleasure?
Old 05-17-2004, 09:55 PM
tenfourtyeight's Avatar
22re.
Old 05-17-2004, 09:59 PM
arjan's Avatar
I've had 2 '91 4Runners. A 2dr with the 22re and a 4dr with the V6. At this point I would choose the 2dr with the 22re. I still miss that truck. It was a base model but in very good shape.
Old 11-27-2004, 08:28 PM
Figit090's Avatar
i found this by mistake but would like to hear more opinions! I will be buying a Yota and want to know which engine is worth getting! Sounds to me like i should avoide the v6....
Old 11-27-2004, 08:38 PM
kyle_22r's Avatar
fuel injection, pfft! gimme a regular old 22R or 20R
Old 11-27-2004, 09:10 PM
ekim121's Avatar
The 22re rules. I have pretty moderate mechanical knowledge but was able to tear it apart and replace the headgasket in a day. It makes good power, gets good gas mileage, and is easy to work on...what more could you want?
Old 11-28-2004, 12:45 PM
AgRunner06's Avatar
I wish I had the 22re.
Old 11-28-2004, 12:57 PM
Churnd's Avatar
Torque.
I had both, and I'd still choose a 3VZE over the 22RE. Granted, I never had to tear the engine apart and replace a head gasket on the 3VZE, but isn't that saying something in itself?
Old 11-28-2004, 01:54 PM
wvuviv30's Avatar
22RE... better power to weight ratio... also better MPG
Old 11-28-2004, 01:56 PM
SolidDigital's Avatar
if my truck were an extended cab I'd keep it forever, but it's not so it'd be nice if it were a 22re. better gas mileage.
I'd like to get an extended cab with the 3.0 and 4.56 gears, then I could just swap in a 3.4 when the 3.0 got tired.
Old 11-28-2004, 04:58 PM
Pedrokep's Avatar
22re for me. My first car was a 1987 4runner with a 22re and i sold it with 250K miles on the engine, still running fine it just had alot of body rust. I had a 90 4runner with a 3vze that burned oil like crazy, its engine blew due to low oil in october. Now I have a 94 4runner and it has the 3vze. I am going to keep my eye on the oil for this one.
Old 11-28-2004, 06:36 PM
Yamaha+Toyota=Fun's Avatar
22re I got one, and I like it.
Old 11-28-2004, 07:24 PM
ZeroYota's Avatar
I just picked up my first Toyota pickup, an 84 SR5 with 22RE. The reason why I chose this over other 2wd pickups was because of the engine & it only cost me $500Cdn. The best part is that it runs good, so I don't have to tear into just yet. When I do, I'll rebuild it with LC Engineering goodies.
Old 11-28-2004, 07:29 PM
JEDI87's Avatar
Well I have both.my 87 with 33's and a bad motor is faster,better on gas and a lot cheaper to work on.I have had to put over 2000 bucks into my v6 within a year and about 200 in the 87 in 4 years.
Old 11-28-2004, 09:04 PM
fiveofeen's Avatar
personally i'd still take the 6cly over the 22re, that an its gotta be easier to swap a 3.4 in a 3.0 equipped runner
Old 11-28-2004, 10:01 PM
Silver_Truck's Avatar
I like my 3.0
Old 11-28-2004, 10:31 PM
ChickenLover's Avatar
Originally Posted by Silver_Truck
I like my 3.0
Ditto. The 3.0 gets a bad rap. My well tuned, slightly modified 3VZE gets over 300miles to a tank on the highway and has plenty of power. I haven't had any problems with my 3.0 and I definately prefer it to the 4cyl.
Old 11-28-2004, 11:19 PM
GregStevens's Avatar
I have never driven or even ridden in a 22RE Runner, but I'm certainly not disatisfied with the performance of my 3VZE. And last week, I cleaned out the throttle body and holy crap, there was a lot of holy crap in there. Now it gets off the line quicker, throttle reponse seems better and it starts immediately every time now...which it was, occasionally, having trouble with before. I think a properly tuned 3VZE will, except for the mileage, be a better choice. It's not a monster powerplant, but it works well in my Runner.
My vote is for the 3VZE.
Old 11-29-2004, 06:23 AM
JEDI87's Avatar
Cost for repairs and parts are so much more than the 22re.My water pump for the 22re was 40 and I could do it myself.The v6 was more than 700 (had it done).The 22re still gets up quiker than my v6.I get over 300 miles to the tank in my lifted 87 22re and 200-230 in my stock v6.
Old 11-29-2004, 11:28 AM
Bumpin' Yota's Avatar
3vze hands down.
I just swapped the waterpump, idlers, timing belt, coolant, belts, crank seal, oil, filter, thermostat, reset the timing to 10* BTDC, put in some 93 octane, and some octane booster....
My truck now leaves two 4" deep ruts 20 feet long in the hardpacked shell driveway when I stomp the gas....Low end torque of the 3vze is where it's at.
256,000 and climbing on the stock HG too.
19-20mpg on the highway too....
Ill keep my 3vze, but if yall want to get rid of yours just drop me a line!!
Quick Reply: POLL: Who wants 22RE over 3VZE? Count me in!
