Pls Advise: Re-Wire Cigarette Lighter?
... trust me... that will bite you later when you forget to turn the stereo off and the battery goes dead even though your charger is plugged in.
A final note for anyone in the future who does what I did... a few days after I re-wired everything I was reading the manual that came with my CD deck, and noticed it said that it should only be connected to the ACC wire, because connecting it to a power wire might cause battery drain. The deck can connect to lots of extraneous devices (DVD player, iPod, amp, SW...) and I don't have it attached to anything, so I figured, eh. How much can the drain be when it isn't attached to anything AND I have a solar trickle charger going. Flash forward 2 weeks later, and today I ran out to use the truck and it was dead. Last time I drove it was a few days ago. So it must have been gradually losing juice all along, and too much for the trickle charger to compensate for, cause I have been driving it every few days since I re-wired it, but only short, around-town trips that probably use more juice than they generate.
So I re-wired the old cig lighter wire (that also provides radio power) to an ACC wire at the fuse box. The moral of the story... read your CD deck manual before you wire the radio to use a constant power source. And from now on, when I buy a deck I'm going to look for one that does not cause drain. "In the old days" the decks were always powered to a hot wire and never caused drain! Using ACC for the radio sucks!
bigblue82
10
07-06-2015 08:27 AM
