pitman arm help
Its a regular rear solid axle out of an IFS equipped Toyota 4X4. They are stronger, wider and have bigger brakes than the '85 and older rear axles.
I had bent my axle/housing when I rolled my truck so I figured I might as well get the improved axle under it since its an upgrade. Bolts right up but needs to use the u bolts and plate that came with the replacement axle since it is thicker too.
JookUpVandetti
09-30-2015 08:58 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
