Pinion replacement
Old 05-05-2011, 12:46 PM
jbeerheart's Avatar
Pinion replacement
searched but could find anything solid on this topic, i'm leaking gear oil near my rear differential, and i'm told i need to replace my entire rear pinion for $885 cause it has some serious issues, is there anyway i can confirm this diagnostic and do it myself?
Old 05-05-2011, 12:54 PM
sebastianholmes's Avatar
wheres it leaking from? pics? does it make any noises? you probably just need a new pinion seal, it should be like 10 bucks plus labor if you dont do it yourself.
Old 05-05-2011, 01:02 PM
ZUK
ZUK's Avatar
Cost you 15 for the seal if you do it yourself
https://www.yotatech.com/search.php?searchid=8595121
Old 05-05-2011, 01:08 PM
badattitude's Avatar
Probally just need a new seal.
Old 05-05-2011, 02:20 PM
anthony1's Avatar
Wow 885 to fix the leak?...
it must be all labor charges. If the pinion seal is bad, remove the drive-shaft, becareful not to pull it apart, then remove the nut. replace the seal. put the nut back.
If it's the between the axle housing and the diff, you need to remove the two rear axle then drain the oil. clean off the old gasket, replace with new gasket and some sealant. put everything back...
Old 05-05-2011, 02:24 PM
Junkers88's Avatar
Almost 900$ to fix a leaking seal in the rear end?? I'm in the wrong business. Do like others have said and fix it yourself. Toyota's are crazy easy to work on.
Old 05-05-2011, 03:17 PM
its not $885 to replace the seal, whoever gave him that price thinks there is serious issues and he needs a new pinion gear. they clearly know nothing, and he should replace his seal himself. its like an hour job, correct?
Old 05-05-2011, 05:25 PM
jbeerheart's Avatar
its making a noise, i dont have any pictures but its leaking where (i think its the drive shaft) connects to the axle. also been riding reallly rough lately, mainly at idle, just knocks around but i dont know if that has anything to do with the rear end or not. if its just the seal ill definitely replace it myself, but how will i be able to tell if theres anymore serious damage to the pinion?
Old 05-05-2011, 05:58 PM
ZUK
ZUK's Avatar
Some people would just replace the seal...set the pinion pre-load light by tightening the nut just right...and see if the noise went away. If it's still noisy, then you have other issues....maybe the outer pinion bearing is chewed up. But do the easy thing first and see how it flies.
Old 05-05-2011, 06:17 PM
bugs1961's Avatar
I had a crush sleeve collapse once causing the pinion to lose the preload. This allowed the pinion to wiggle around and ruin the seal. A new crush sleeve and seal fixed the problem, although a tiny torque wrench designed for setting the preload was mandatory to get the preload set properly. No problems for 6 years so far.
PS: ZUK, I did your spring mod last week and absolutely love it!
Old 05-05-2011, 06:22 PM
ZUK
ZUK's Avatar
Originally Posted by bugs1961
I had a crush sleeve collapse once causing the pinion to loose the preload. This allowed the pinion to wiggle around and ruin the seal. A new crush sleeve and seal fixed the problem, although a tiny torque wrench designed for setting the preload was mandatory to get the preload set properly. No problems for 6 years so far.
Cool, bugs if you have pics you can post them to one of the related links and let us know what coils you ended up with and how much lift....and what was different about the ride afterwards
oops...offtopic
ZUK
Old 05-05-2011, 06:35 PM
bugs1961's Avatar
oops...offtopic
ZUK
One more off topic! I'm out of town for another 10 days or so but I'll do it when I get back to Anchorage. I used the 14", 100lb coils and they gave a bunch of lift. Went from a sag to a rake but that's ok with me. I'll crank the torsion bars some or get ball joint spacers one of these days. Great mod--thanks much!!
Bugs
Old 05-06-2011, 07:44 AM
anthony1's Avatar
Check your u-joint when you separate it from the diff. Make sure they move freely at all angles. Mine frooze up and it made a nasty grinding noise. Mark the slip yoke in case it slip out. You can also hang the d-shaft on the cross member with zip ties or rope...
Old 05-06-2011, 11:45 AM
Junkers88's Avatar
its making a noise, i dont have any pictures but its leaking where (i think its the drive shaft) connects to the axle. also been riding reallly rough lately, mainly at idle, just knocks around but i dont know if that has anything to do with the rear end or not. ?
Rough idle has nothing to do with the rear seal, you probably know that though. When you say rough is it missing? Choking out? Hesitation from a stop? You might need just a tune up. I had a rough idle on both rigs at one time or another and it can be anything from bad plugs to the TPS to a blown intake gasket.
Old 05-11-2011, 05:06 PM
jbeerheart's Avatar
hey got the seal replaced finally, but im still hearing a buzzing/ whirring sound that comes only when im accelerating once i hit around 20-25, any ideas what it could be?
Old 05-17-2011, 03:30 PM
bigsaltywalter's Avatar
still sounds like the bearings are worn. does the companion flange behind the nut move around and seem very sloppy? preload is one thing, but worn or chewed up bearings are another. my yota was doing the same thing for a while, and now the pinion moves around quite a bit as noted by the flange movement and makes a horrible noise when driven. i would look into replacing those bearings!
Old 09-11-2011, 07:37 PM
Trooper's Avatar
Man, used third members are a dime a dozen. I'd try to track one down and swap it out. 20 minute job. Even if it took all day it's better than paying almost a grand for a friggin third member. That's insane. You absolutely can rebuild the thing with a little know-how, but used thirds can be had for less than the cost of new pinion bearings and are practically zero headache! good luck bud!
the1998sr5
15
07-14-2020 08:35 PM
oldirtydirt
02-23-2020 09:30 AM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
1994toyota
07-17-2015 03:03 AM
Quick Reply: Pinion replacement
