| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Pinion angle adjustment with 1" drivetrain lift
__________________
1990 SR5 V6 Standard Cab Short Bed 4X4 5 Speed Last edited by Snorkeldepth; 04-06-2006 at 12:24 PM. |
#2 (permalink) |
I would link you proablly dont have to worry about it, but if you do its just a small shim under the rear leavel. If you have the stock shock setup you should be able to go up to 6 degrees, but I doubt you need more than 2 if any.
As for the front, your still running IFS right, I wouldnt worry about..
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#3 (permalink) |
Thanks nala! Yep, still IFS in front. So, 2 if any in the rear. Cool!
__________________
1990 SR5 V6 Standard Cab Short Bed 4X4 5 Speed |
#4 (permalink) | |
Quote:
http://www.4crawler.com/4x4/CheapTri...l#Measurements And if you want to pre-figure the angle change (with an uneven drivetrain lift), dig out your old trig book. Simply measure the horizontal separation between the pair of motor mounts up front and the tranny mount in the rear. Then just divide that into the lift height difference (end to end) and take the inverse tangent (arctan) of that ratio. At about 44" more or less between those points, you get about 1 degree angle change per inch of uneven lift. As far as the front angle change, not a lot you can do about that on IFS since the diff bolts to the frame. Only issue would be some vibration during high speed 4WD operation.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 02-29-2008 at 09:31 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Adjusting rear pinion angle on Gen II 4Runner | FredTJ | 86-95 Trucks & 4Runners | 3 | 09-18-2006 10:01 PM |
| Changing pinion angle....SFA | Marc P | Offroad Tech | 8 | 08-31-2006 12:28 PM |
| 3" Drivetrain/Body Lift + New Crossmembers = ... | ravencr | Offroad Tech | 59 | 03-21-2006 04:01 PM |
| Bud Built crossmember for 3.0 5spd with 3/4" drivetrain lift (pics) | rocket | The Classifieds GraveYard | 14 | 02-22-2006 01:25 PM |
