pinhole leak/crack in top of radiator
I have a 95 3l 4runner. I have a pinhole leak on the top of my radiator near the fill spout. what kind of solder should I use to fix it. I know I need to drop the fluid level before
I used a MAPP gas torch & standard solder to fix the pinholes that developed in mine at the top; this must be a common failure. My radiator has worked fine for over 130,000 miles since then...
Mine has a row of pinholes in there, my guesses are from not changing the coolant and the ridges on the top of the rad create kinda a "vortex" if you will effect on the fluid.
jasonty
41
12-23-2018 01:00 PM
JaredL
03-28-2016 09:08 PM
Road Bull
10-10-2015 04:55 PM
TJWilly
07-31-2015 02:05 PM
