Pinch Weld and new 33x10.5 tsl's
Old 05-07-2008, 03:45 AM
blueyoda's Avatar
Hello,
I ordered a set of 33x10.5 tsl radials yesterday and have a few question? I have a few sets of rims available to put them on, factory steel for 31", AR aluminums, and ar steelies, I looked a as many threads as possilbe but could not find pics of the pinch weld mod? Also a backspacing link that was posted states that the greater the backspacing the less your tire stick out, this seems to be contrary to what people are saying,(https://www.rsracing.com/tech-wheel.html#backspace). What wheels do you guys recomend for the tsl's and where is the pinch weld?
Thanks
Old 05-07-2008, 07:23 AM
AxleIke's Avatar
The pinch weld mod is simply pounding the pinch weld flat. No pics needed. You use a BFH.
Old 05-07-2008, 07:25 AM
AxleIke's Avatar
The pinch weld is behind the plastic insert at the rear of your front fender. Remove the insert, pound it flat, and replace the insert.
Old 05-07-2008, 07:27 AM
Djlarroc's Avatar
Don't forget the BFH.
Old 05-07-2008, 07:39 AM
4Crawler's Avatar
Originally Posted by blueyoda
Hello,
Thanks
Use the factory rims, they will work fine. Backspacing on that page is properly defined/described. Just realize that the picture of the backspacing is with the rims upside down.
Pinch weld picture:
Old 05-07-2008, 08:55 AM
norcalsvx's Avatar
hammer it flat
Old 05-08-2008, 06:04 AM
blueyoda's Avatar
Thanks, I will try to prep the steelies and put them on steel, The pinch weld looks simple enough I look forward to throwin some mud
ladybugRC
458
08-21-2020 10:41 AM
tazman1972
11
09-28-2015 10:32 PM
runnermedic
13
09-21-2015 05:20 PM
sonorn67
09-19-2015 05:39 PM
themightykhoner
09-18-2015 02:28 AM
Quick Reply: Pinch Weld and new 33x10.5 tsl's
