PCV Hose Location for 3.0L '95 4Runner?
I wanna add some seafoam to my 95' 4Runner, can someone point out the PCV hose where I'm suppose to pour the seafoam in?
Thanks.
P.S. It's for a 3.0L engine.
Thanks.
Seafoam
I used a 3/8"male barbed X 1/8" male barbed adapter and a small length of 1/8" tubing (that way not so hard to keep running with PCV disconnected) and sucked it out of the can (whole can) throttling it while it was sucking it in then followed the rest of the directions , it did a beutiful job on the throttle body and throttle plate but that was as far as I could really see , I am sure it cleaned the rest as good
That in my gas and my intake has helped mine purr a bit better
It would probably not be a good to pour it in as that possibly could cause a problem if you actually got liquid to the combustion chamber .....................would not be pretty
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
Avenged
07-09-2015 07:55 AM
skoti89
07-08-2015 12:05 AM
