PAIR Valve, Oil Filter, amnd Sluggish Fuel Injection for 1994 Toyota Pickup
PAIR Valve, Oil Filter, and Sluggish Fuel Injection for 1994 Toyota Pickup
1994 3.0 Liter, 3VZE engine, V6 Xtracab Pickup. 75,000 miles. (I know, right!?)
I have 3 different issues:
1) I power washed my engine last summer and now I am having trouble with the PAIR valve, I believe. When the engine's cold it makes a throaty, guttural sound until it warms up, and there is a strong smell of unburned gasoline from the emissions. Where can I get a replacement PAIR valve? Also, is there potentially a different fix for this? Maybe replacing a piece of the hose or the internal reed? I don't know much, so try to tell me like I'm 5.
2) It's also been having trouble injecting gas going from 1st to 2nd gear, it seems. I need to almost floor it so it won't stall. Any thoughts on this? It also only really happens when the engine is cold.
3) I changed my oil myself for the first time last week but I couldn't get to the oil filter. Any tricks to this? I'm such a n00b.
I also need some other parts. My entire jack assembly was stolen so I need a tire iron, Rod and extension assays, lever/jack handle, etc. Anyone know where I can order parts for my rig? I tried www.toyotaprtsoverstock.com but they didn't have everything I needed.
Any help and/or info would be much appreciated!
The PAIR valve has four phillips-head screws that hold the metal cover to the aluminum casting.
If you lose one (or two or three) of these screws, the cover will vibrate (more a humming sound than "guttural," but who knows?) If you're missing some, it's easier to replace them with socket-head screws, as it's unlikely you have a screwdriver short enough.
Is the unburned gas smell under the hood or at the tailpipe? Under the hood: check the evap canister. If you knocked a line off, it will overfill and leak raw gas.
Where is your timing (ignition) set? Yeah, it takes a $20 tool to check, but that check is basic that you're wasting your time until you get it done.
Staff
I have found a few tool kits in the boneyard. Just have to keep searching. I had a flat yesterday and with the factory tool kit I was unable to break a lugnut loose. Luckily I keep a 4 way lug wrench tucked into my spare tire. I put it in my Tools, Tips, and Tricks thread (link below) yesterday as I would of been in a bad situation with out the 4 way. I have an 01 4Runner as well and its jack looks the same as my mid 80's trucks so several Toyotas might work for what you are looking for.
Peteyg39@hotmail.com
06-26-2015 08:15 AM
dlotoy4runner
7
07-09-2002 01:11 PM
