P/S pully fell off!
Old 12-07-2013, 06:39 PM
chance91yota's Avatar
P/S pully fell off!
Hello! This is my first post and I need some help, so I was out playing in the snow when I lost my power steering. I assumed I slipped a belt. Upon getting out and looking in the engine bay I see not only had I slipped the belt, I had lost the whole bottom pulley. In this picture I am missing the pulley closest to the radiator on the harmonic balancer. I'm lost as to what to do and any help would be greatly appreciated. Also I did a fair amount of searching and cant find anything on this subject!
Attached Thumbnails P/S pully fell off!-img_0944.jpg
Old 12-07-2013, 06:46 PM
HighLux's Avatar
have any more pics?
Old 12-07-2013, 06:47 PM
JasonYota's Avatar
Welcome from Alabama
Did you completely lose the pulley? Like you can't find? You could start looking in junk yards for one or parts houses might have one
Old 12-07-2013, 07:06 PM
I recovered the pulley of my skid plate haha. but all I have is a big ring? I will take pictures in the morning
Old 12-07-2013, 07:13 PM
bone collector's Avatar
Im trying to figure out what broke. Is the crank bolt still there?? or is it the 4 little bolts that hold the pulleys together?
Old 12-07-2013, 07:18 PM
This is all I have! It looks like it just fell off from the other two pulleys?? Sorry phone picture!
Attached Thumbnails P/S pully fell off!-img_0119.jpg
Old 12-07-2013, 07:22 PM
All 4 bolts are on, and the crank bolt I believe, but its hard to see it in the dark! I felt all bolts but cant see much with fan shroud on.
Old 12-07-2013, 07:26 PM
wow... crazy stuff. you definitely need to pull off the rest of the crank pulley to see what happened
Old 12-07-2013, 07:29 PM
So im guessing this is not common? my luck!
Old 12-07-2013, 07:33 PM
I just remembered, when I put a timing light on my engine the timing mark continuously spun? Could these be related? like instead of it showing actual timing it would just keep spinning around quite slowly
Old 12-07-2013, 07:34 PM
not that I have seen. Not saying it hasn't happened before, but I wouldn't say its common
Old 12-07-2013, 07:38 PM
JasonYota's Avatar
If the timing mark your talking about is on the balancer it should spin with the engine running
Old 12-07-2013, 07:43 PM
Yes but with a timing light, the mark should stay in the same spot. Yes it sounds like you had an issue before your wheeling trip
But with the timing light on plug wire 1 it should be flashing the timing mark on the timing marker above the balancer. (cant think of the name!) Just like any other engine Iv worked on I would think?
Old 12-07-2013, 07:45 PM
Not sure I'd call it a wheeling trip We just got about 3 inches of snow so i was out in the desert with some friends mudding through some icy puddles! My truck does not deserve what I do to it!
Old 12-07-2013, 07:49 PM
http://personal.utulsa.edu/~nathan-b...67timingbe.pdf
based on the pictures in this diagram. and your picture. it looks like the pulley sheared from the mounting plate that has the 4 bolts. in the morning I would be curious if there are 4 bolts on the crank pulley that are holding a plate with no pulley
Old 12-07-2013, 07:51 PM
any clue where i can find a replacement? Am I stuck with going to the dealership?
Old 12-07-2013, 07:54 PM
local junkyard???
Old 12-07-2013, 07:56 PM
Ill look into it, they want an arm and a leg for everything! 2 tail light covers 40 bucks each??? new 50 for 2 i told them to shove it at that price!
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
bobpat
08-01-2015 09:25 PM
thefishguy77
07-30-2015 10:59 AM
cgilley
07-25-2015 10:55 PM
Quick Reply: P/S pully fell off!
