Overdrive?
Old 03-26-2007, 04:27 PM
Barker87's Avatar
Overdrive?
I have a 1995 4runner,(6 cylinders, 3.0, automatic) and my truck started having problems with shifting to overdrive. Can anyone help?
Old 03-26-2007, 05:55 PM
CoedNaked's Avatar
Hows your transmission fluid? Has it been changed regularly?
When does the problem occur? When the engine/transmission are cold? warm? Both?
Does it have hard shifts in any of the other gears?
Have you turned your O/D off recently? did you turn it back on?
Old 03-26-2007, 07:39 PM
Barker87's Avatar
Its fresh I changed it last month and the filter. It occurs more whenits cold but it will sometimes do it when its hot(rare) this just started last week. All the other gears are fine. I tried turning the O/D off then back on, just to see if maybe the switch was messed up. Do you have any ideas?
Old 03-26-2007, 07:41 PM
slosurfer's Avatar
What size tires and gears are you running?
Old 03-26-2007, 07:47 PM
ChickenLover's Avatar
It is normal for O/D to be locked out when the engine is cold. Did you recently change to a different thermostat?
Old 03-26-2007, 07:53 PM
Barker87's Avatar
Tires are 35s and the gears are just stock I havent messed with them, I actually dont have my thermostat in right now, because I wrecked my truck got it worked on and fixed and I was having problems and that was one of the things we thought was wrong so we took it out(it was the problem) and I havent had time to put it back in. Does that actually effect the ovedrive?
Old 03-26-2007, 07:56 PM
slosurfer's Avatar
I have 33's and 4.88's and I don't hold overdrive very well, so I think that is your problem. What were the stock size tires for your truck? I don't know if I would ever make it to overdrive with my stock gears!
Old 03-26-2007, 07:58 PM
Yes. Your engine is over cooling. Until it reaches normal operating temp, it will not shift into o/d.
Old 03-26-2007, 08:04 PM
Barker87's Avatar
Well I havent changed my tires or gears since Ive had the truck and it was perfect before the wreck, so I'm not sure if that would be the problem. Ill put the thermostat in tomorrow and see what happens. Thanks for your help guys. What would the stock gears be anyway.
Old 03-26-2007, 08:14 PM
trythis's Avatar
Thermostat X2
best bet is to get the OEM thermostat, some of the aftermarket version wont work right.
Old 03-27-2007, 09:07 AM
snap-on's Avatar
i have a torque converter lockup issue that is intermediate. (it wont lock up on OD)
Its nice in that the motor finnaly runs in the sweetspot RMP range, but damn its nothing but a heat generator and pegs my trans temp with in 30 min or so.
Liadrin
04-25-2022 02:54 PM
chuckross1957
06-28-2019 10:19 PM
crammit442
7
11-29-2017 12:30 PM
rmill05
09-27-2015 01:43 PM
keithporter83
07-24-2015 07:37 AM
Quick Reply: Overdrive?
