optima red-top discharge question
Old 01-10-2008, 07:48 PM
taikowaza's Avatar
my rustbuster/immobilizer electrical draw
my rustbuster is the counteract rust inhibitor, marketed in canada and called couplertec in australia. hard to find in the US I think, I like it a lot. I have this one but branded as a Canadian 'counteract'.
it should not drain the battery as "it shuts off when the battery reaches 80% of capacity..
the immobilizer however doesn't know about battery I think.
the combination of these 2 drained the optima out.
next time I won't be starting the engine for a few weeks, is it safe to disconnect the battery, do I need to wrap up the terminals or posts for safety?
Old 01-10-2008, 08:30 PM
MMA_Alex's Avatar
you can disconnect the battery, but you shouldn't have to. something else is causing a drain. Ps. that rust prevention stuff is crap. if you want proof take a look at my old explorer...
If you really want to disconnect the batt they sell a thing that goes on the cable end that will let you disconnect it just by turning a knob/switch.
Old 01-10-2008, 08:56 PM
taikowaza's Avatar
battery disconnect switch
MMA_Alex is this what you mean? do you recommend one of these if I park for a long time in the future?
Old 01-11-2008, 05:45 PM
MMA_Alex's Avatar
yup. never seen that clock/radio settings thingy though
Old 01-11-2008, 07:49 PM
  #25
taikowaza's Avatar
got the odyssey battery!
turns out that my optima red-top was indeed shot! It wouldn't take a charge and keep it anymore (they had it charging all day and night and no cigar).
So I got a full refund on my optima and went for the odyssey 1500 in its place.
I also got the quick-release post put on just for in case I ever have to park it for a long time again.
here's some pics. also, from the odyssey site:
"The Odyssey PC1500DT is the same size as a typical Optima Red, Yellow or Blue top, with more cranking power, more reserve capacity, longer design life, and a better warranty'.
thanks to everybody who helped me with this issue and advised me towards this battery! one immediate difference is the starting is much snappier! thanks again
taiko
Attached Thumbnails optima red-top discharge question-loaneryt.jpg   optima red-top discharge question-odysseyyt.jpg   optima red-top discharge question-quickconnectyt.jpg
lectric80
08-11-2015 12:02 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
4Runnin2000
07-29-2015 06:09 PM
Quick Reply: optima red-top discharge question
