Oil Leak near the Oil filter
Old 09-25-2006, 09:57 PM
Myron's Avatar
Hi, Just wondering if any one came across this issue. When the truck is running, oill leakes from around the oil filter area.....
I just got this truck and dont kwno when it had an oil change. It was sitting for 3 months before i got it..
Any help will be lovely.
thanks
I have a 88 4x4 EFI 2.4l
Old 09-26-2006, 01:02 AM
ovrrdrive's Avatar
Start with an oil change and a new filter to make sure you have enough oil in it and a good filter. Seeing as how its new to you, you'd be better off knowing it had fresh oil in it anyway.
That would also rule out a bad oil filter seal too.
Old 09-26-2006, 03:06 AM
tampabayota's Avatar
my suggustion to you would be to take pixs and give more info
Old 09-26-2006, 04:06 AM
ovrrdrive's Avatar
pics of a leaking oil filter?
Old 09-26-2006, 04:10 AM
Yoda's Avatar
Sometimes the oil pressure sender may leak. It is right next to the filter (behind it)
Old 09-26-2006, 04:57 AM
MMA_Alex's Avatar
definately do the oil/filter change, and make sure there aren't any old seals stuck in there.
Old 09-26-2006, 06:24 AM
AH64ID's Avatar
that was my first thought...
change the oil/filter... clean it all up and see where/if the problem continues. It could be that the gasket cracked after sitting for 3 months...
the1998sr5
15
07-14-2020 08:35 PM
Eggslinger
06-08-2019 03:32 PM
jasonty
41
12-23-2018 01:00 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
jakebarrett
07-10-2015 07:15 PM
Quick Reply: Oil Leak near the Oil filter
