oil cooler
oil cooler
I have a 94 4runner that spun a bearing. I have located what appears to be an oil cooler on right hand side of block . Can this part be cleaned or does it have to be replaced. I am afraid metal shavings might have gotten into this part. Can anyone help?
yes you can clean it out. It would work best if you had a solvent tank but if you don't then you can run carb cleaner or smething of the sort through both ends. Run alot through and blow it out well with air
