Odd Question About My truck
Old 10-29-2009, 02:21 PM
weaselman's Avatar
so i am using some aircraft remover on my truck, is the grey color the bare metal? or is it primer? it does not react to the aircraft remover or paint stripper.
here are a few pictures.. the shiny part is the part i have sanded..is it just shiny becuz of the sand paper? and if you look closely, you can see the metal, grey and then brown original paint. idk. im confused.
any input would be greatly appreciated...
Old 10-29-2009, 02:23 PM
toyospearo's Avatar
What exactly are you trying to do??
It looks like primer to me
In the second picture in the upper left hand corner that is bare metal. The pic were you have feathered out the paint shows the layers. Paint, Primer, metal.
Keep the primer on unless you need to do body work. It will save you time. When you have everything golden and ready to shoot hiit it with fill primer and paint it.
Old 10-29-2009, 02:24 PM
weaselman's Avatar
thats what i figured.. shouldnt the primer react to the aircraft remover tho???
Old 10-29-2009, 02:26 PM
MuddinRI's Avatar
Keep the primer save a step if you can just clean the truck with asetone. i took a 67 mustangs paint off with a razor blade and left the primer
Old 10-29-2009, 02:27 PM
toyospearo's Avatar
That is a question for someone who knows about aircraft paint remover. That is kinda random
4Crawler's Avatar
Might be some sort of hot dip rustproofing coating:
- http://en.wikipedia.org/wiki/Rustproofing
MuddinRI's Avatar
it's not a paint primer it's medal bond primer helps paint stick and stay
Old 10-29-2009, 02:28 PM
MuddinRI's Avatar
and like that guy said it stops rust or atleast tries
Old 10-29-2009, 05:38 PM
weaselman's Avatar
thank you for such helpful replies and links. i think im going to be keeping that layer of primer. and just sand it a bit...
i also forgot to mention. that when the original brown paint comes up. its is grey on the back side of it.... soooo.. im just gna leave that primer and sand it up a bit.
Old 10-29-2009, 05:46 PM
toyospearo's Avatar
I suppose it really depends on what kind of paint and finish and look you are after. If you sand it with 220 grit then 320 grit and it sands out just right you'll have a prepared surface for just about any paint.
Old 10-29-2009, 07:29 PM
weaselman's Avatar
this is what im doing...
https://www.yotatech.com/forums/f116...-truck-195393/
GreenLion
06-07-2021 10:49 AM
streetuner15
06-18-2015 10:59 PM
Mutinebullfrog
06-18-2015 01:36 PM
CLin9383
06-27-2002 08:28 AM
Quick Reply: Odd Question About My truck
