o2 sensor male plug
Old 07-12-2011, 11:34 AM
nutta91's Avatar
o2 sensor male plug
so my truck is missing the male end of the o2 sensor amd was wondering what other models have same plug in and o2 sensor? my truck is 1991 22re with 4wd. I need the model and years as I am going to junk yard to look thanks
Old 07-12-2011, 11:39 AM
xxxtreme22r's Avatar
cali emissions? or just federal?
Old 07-12-2011, 11:43 AM
4Crawler's Avatar
Likely any pickups of the same generation ('89-'95) or 2nd gen 4Runners. Should be a 4-wire connector (heated sensor) vs. the unheated 1-wire sensors on the earlier trucks. Not sure the year of the switch over. Should be able to pop the connector off the sensor in the donor vehicle and see if it looks the same as your sensor (bring your sensor along for a test fit if unsure).
Old 07-12-2011, 11:46 AM
oh also if cali spec #1 or #2 sensor? Pretty sure 4crawler is right, I am just gonna cross reference actual o2 sensors, but the plugs might cover a wider range.
Old 07-12-2011, 01:02 PM
nutta91's Avatar
its a fed with obly one and I dont have a male end so ill have to buy a o2 as well
montanatruck
02-26-2017 07:07 AM
raptor510
02-17-2017 07:11 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
msane99
07-17-2015 10:13 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: o2 sensor male plug
