| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
o2 sensor and exhaust questions
#2 (permalink) |
I'm sure someone has a "used" downpipe they'd sell for cheap.. I think I tossed mine in the trash a few weeks ago.
I like to use stainless bolts and a lot of anti-sieze when working on the exhaust. Just get the old bolt out and re-tap. Use stainless.. It takes a lot longer to get crapped up. On your 02, the connector is under the seat. You'll have to post a photo of your "new" 02 sensor. Wire gauge isn't that important, but wire function is. The 22RE has a heated 02 sensor and you need to get the wires right. Most aftermarket sensors come in flavors from 1 to 4 wires. Splice in the connector from the old 02 after you correctly figure out the function of the existing wires. More info is needed! If you're in a rust prone area, you can go to "aluminized" exhaust, stainless, or just try and keep the salt off those parts. Other than ceramic, there isn't a good coating that I know of.
__________________
http://www.22REturbo.net |
#3 (permalink) |
thanks for that info...my new o2 sensor has only 1 wire going to the little round plastic connector, will this fit somewhere along the line of where the current o2 sensor path to the ECU or will i have to do some splicing as you mentioned even if the current o2 sensor has more than 1 wire?
Also does anyone know the best way to remove the nuts on the manifold without snapping the bolts? Drew |
#4 (permalink) |
Drew, if you've got a one wire sensor, you need to figure out which wire is the ECU 02 gauge.. there may be two, one is for the 02 value, one is a ground for 02 heat.. .You want the 02 value.
Note a heated sensor is better, especially that far from the manifold. Best way to get them exhaust bolts off is to soak them in some penetrating oil several times over 24-48 hours... And then cross your fingers...
__________________
#5 (permalink) | |
Quote:
__________________
Toyota Master Diagnostic Technician "MDT" 1998 Toyota Tacoma TRD V6 4WD 5 SPD 1998 Chevrolet K1500 1999 Toyota Camry 2003 Toyota Highlander 4WD 2007 KTM 85SX 17/14 2006 KTM 300XC-W 2005 KTM 65SX 2004 Kawasaki KLX 110 2003 Honda XR50 2002 Yamaha TTR 125L 2002 Kawasaki KLR650 2002 Suzuki Eiger 400 4WD 2004 Cargomate<--link GeePaw® Racing<--link |
#6 (permalink) |
cool, thanks for the info, will try all of that and if I don't come back to this thread then I haven't cracked a bolt and have found the right place for the sensor. fingers crossed!
Drew |
#7 (permalink) |
ok, i'm back, but i haven't broken anything...instead i'm trying to figure something else out...I got a 1 wire o2 sensor from a guy i got some parts from as a freebie. i've got a 4 wire sensor in the truck now and i'd like to try use that other one i have because i'm pretty sure that my current one isn't very good. i know that dcg9381 said that i need to find that wire for the o2 value going to the ecu. question is: how do i find the right wire, and will not using the other 3 wires make anything go awry? the o2 sensor is up on the manifold so i shouldn't have to worry about heat eh?
thanks in advance, Drew |
#8 (permalink) |
Id look into a header
I put a all new exhaust on my rig after i bought it. I bought it with a cut head pipe (dumped under the cab before the cat) ... it was a mess and louder than hell. So I had a shop order a new head pipe ($200, yea no lube either when i walked in backwards)... Then I had to buy a new exhaust manifold. In the end i was out $550 for a stock exhaust, well i have a magnaflow on it. Then i went through hell getting the "new" head pipe to seal to the "new" exhaust manifold, broke a stud in it.. Iron manifolds SUCK! and i have the aftermarket 17mm nuts, its a pain in the ass but even with only two bolts holding the head to the manifold it doesnt leak anymore. Proper gaskets are important, home-made or thin paper ones DONT work. You need the three-layer cement type. Anyways, I could of actually saved a $200 if I had gone with a header. (they're like $150-200 on the net). I think engblder sells them to
__________________
1987 Pickup, single cab, 22R, new head, 260 cam TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac. |
#9 (permalink) |
yeah, i want to get a header, that's a future project though, and i do like the LCE ones i think, since they specialise in toyotas, engine builder would also be another option, but when i buy it, money won't be an object (to a certain extent anyway). what i'm wondering is what i need to do in order to hook up a 1 wire o2 sensor to a 4 wire o2 sensor system already in the truck...
thanks, drew |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| replacement exhaust, second O2 sensor? | joea | 86-95 Trucks & 4Runners | 7 | 03-23-2007 03:31 AM |
| New exhaust...O2 sensor location after cat? Need help ASAP | Pozi | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-01-2006 02:43 PM |
| 00 Tacoma O2 Sensor vs A/F Ratio Sensor | ir-rocks | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 04-11-2006 03:49 PM |
| O2 sensor code on 3.0 with new a sensor | rentedmule | 86-95 Trucks & 4Runners | 6 | 01-13-2006 10:53 AM |
| Help on O2 sensor Install (questions on Bobs writeup) | GodwinAustin | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 03-06-2005 03:08 PM |
