o ring mistery ??
Old 03-11-2012, 07:10 AM
Dustysmac's Avatar
o ring mistery ??
I replaced the head gasket on a 1994 22re Toyota pick up. When I finished I found a O ring on the floor. I am not absolutely sure that it came from my repair as the truck is used and it could have fallen from an earlier repair from a previous owner and fell out when I moved something. The O ring is about the size of a penny , any ideas where this O ring may have come from. I did not take off the timing chain cover water pump or anything in that area.
Old 03-11-2012, 08:17 AM
Bassmastry101's Avatar
does it look like it has already been used or is it new? Possibly dropped it out of your gasket kit? Only o-rings that come to mind is distributor or fuel injector. I guess the fastest way to find out is to fire it up and check for leaks, since it's already back together.
Old 03-11-2012, 12:31 PM
Dustysmac's Avatar
It looked flat like it may have been used , it could have come from the distributor, I'll pull it out and check.As for firing it up I have already and it ran like crap. I tried to set timing and when I shorted the "T" it did not change the rpm's at all. Did some research on this great site and found that my TPS was more than likely bad. I checked it with a meter and could not get a reading. So now I have removed the throttle body to get the TPS off and I'm waiting on a TPS I ordered on E bay. I'm going to replace the screws on the TPS with allen head screws when I put it back.
dzldust
7
10-06-2015 05:39 AM
hiluxinargentina
09-30-2015 05:51 PM
JimiJams
09-28-2015 06:14 PM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Quick Reply: o ring mistery ??
