"Normal" valve chatter? 22r
Old 05-06-2011, 04:37 PM
benelli's Avatar
I've adjusted my valve lash at least 4 times and I'm going insane chasing this rattle down, after searching the site is the normal valve chattter that all 22R's sound like? (Yes it has a 22RE valve cover.)
Lemme know what you think!
Old 05-06-2011, 04:46 PM
swampfox's Avatar
Try backing the valve cover nuts off a little,if that doesn't help it is most likely normal.
Old 05-06-2011, 05:15 PM
benelli's Avatar
Forgot to post vid
Old 05-06-2011, 05:18 PM
xxxtreme22r's Avatar
ALmost sounds normal to me, maybe a little noisy fuel pump as well like mine is. But x2 on maybe loosening up and/or replacing the valve cover grommets. If it's tightened down too much a few of the valve rockers can hit the cover. It's doesn't have to be much tighter than hand tight actually. Maybe a half turn if that pass hand tight.
Old 05-06-2011, 05:25 PM
benelli's Avatar
I didn't realize that it will hit the valve cover, I've been cranking them bolts down. I'll loosen them up and give it a try.
If there's any other thought as to what's going on don't be afraid to chime in. Also I've been setting my valves to .06 Intake and .08 exhaust, is that correct?
Old 05-06-2011, 05:33 PM
AmpedRunner's Avatar
i'm pretty sure its 0.08 intake and 0.12 exhaust. if you tighten the clearance too much your in for trouble
Old 05-06-2011, 05:34 PM
talking valve cover not valves.
Just to clarify one thing, did you use a new valve cover gasket and grommets as well? Because those things can flatten out pretty good. If either are wore out or they will affect how close the valve rockers come to the cover as well as how tight they are cranked down.
Old 05-08-2011, 05:00 PM
Nogarage's Avatar
How many miles on the engine (specifically the top end)?
Old 05-09-2011, 11:59 AM
Andrew Lam's Avatar
How tight is tight enough for the valve cover? I just got a new gasket and the half circle gaskets seem to be pretty high. I thought crankig down would help, obviously I'll back off now.
Old 05-09-2011, 01:08 PM
The MAN's Avatar
sounds like rocker arm noise to me
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
akamon808
3.4 Swaps
12-16-2015 08:45 PM
genuinegemini
08-03-2015 04:56 PM
cars-guy
07-11-2015 07:51 PM
87blyota
07-10-2015 04:31 AM
Quick Reply: "Normal" valve chatter? 22r
