normal auto slugg or did i do something wrong
Old 12-12-2008, 09:47 PM
Sponsor
Tofer's Avatar
So i finished swapping in the new tranny in to my 89.... bolted it in, filled it with fluid, fired it up, let it run for a several seconds (minute max) to get fluid moved around, turned it off, topped it off....
now reverse catches and goes when you hit the gas. however, when you put it in drive it doesnt seem like it can get out of its own way.... i have to stomp on it to get it moving and its a DOG.... i only drove it around the shop complex (25mph) but it takes forever to get rollin. it doesnt feel like anything slipping (although i have only ever driven manuals so i only know what a slipping clutch feels like)
is it just normal 3.0+auto + 4.10s? or did do something wrong? i know these are underpowered and i have 5.29s i need to swap in the front and then buy a 5.29 open rear but this seems real bad...
btw i've decided i hate working on autos... give me a 5sp anyday...
Old 12-12-2008, 09:58 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
which tranny? The A340H?
Old 12-12-2008, 10:00 PM
Sponsor
Tofer's Avatar
89 4runner.... a340h right??
Old 12-12-2008, 10:03 PM
Well, there's a A340H, and a A340F. I have the A340H in my '91. Lemme check my FSM's for you, but I wanna say problems with your TC off the top of my head......
but I'm no tranny guy.....
Old 12-12-2008, 10:06 PM
Wait, my FSM shows the following auto trannies : A44D, A340E, A340H, A340F
Old 12-12-2008, 10:17 PM
Ok, the A340H and A340F were both mated to the 3.0 and used in our 4x4's. This is out of the troubleshooting section of my FSM:
Vehicle does not/barely moves in any forward range or reverse:
1) Manual linkage out of adjustment
2)Valve body or primary regulator faulty
3)Parking lock powl faulty
4)Torque converter faulty
5)Converter plate broken
6)Oil pump intake screen blocked
7)Transmission faulty
Old 12-13-2008, 01:44 AM
gte718p's Avatar
Did you fill the torque converter with fluid before installing it?
I don't know a thing about toyota autos. I work on corvettes also and it sounds real similar to the problems people have when they forget to fill the converters on the T350 and T400 transmissions.
Old 12-13-2008, 05:35 AM
InternetRoadkill's Avatar
Shift solenoids are stuck. It's prolly trying to start out in 3rd gear.
Old 12-13-2008, 05:59 AM
Marc's Avatar
Sure you got enough fluid in there?
You have to check it while idling.
Old 12-13-2008, 01:19 PM
JoKEpLaYeR's Avatar
I believe you have to check when idling and in drive?
Old 12-13-2008, 01:39 PM
Marc's Avatar
Wrong. Should be checked in PARK while idling with fluid at operating temp.
Were you guessing?
Old 12-13-2008, 01:41 PM
JoKEpLaYeR's Avatar
Hum, we were taught to check it in Drive in auto shop many years ago. But I'm no auto tranny expert.
Old 12-13-2008, 02:05 PM
abecedarian's Avatar
so you say you have to stomp on it to get it to move...
does the engine rev up high and the truck not move, like a slipping clutch, or does the engine rpms stay low and it's like the parking brake is dragging?
torque converter new also? did you add about 2 qts atf to the torque converter, right?
all told, with tc and trans both dry, takes a little over 10 qts fluid to fill the a340 series trans, about 6-7 qts for a44d.
Old 12-13-2008, 04:48 PM
FredTJ's Avatar
You don't have to fill the TC first before stabbing it into the tranny.
Since reverse works, it's unlikely to be the TC..
My bet is stuck solenoid(s) and or valve(s) in the VB.
You do have it filled completely, right ?
Fred
Old 12-13-2008, 04:50 PM
Sponsor
Tofer's Avatar
i put another qt in tongiht and it seems to being doing better. revers and Low catch.. 2nd and drive still are slow. also the transfer case doesnt not apepar to be working 4low doesnt have any gear reduction.
when i stand on it, it feels like there ebrake is set... revs stay low and it just drags. does NOT feel like slipping clutch.
i didnt not put 2qts in there was some oil in it and i was told that it would fill up once its installed from the tranny.
Old 12-13-2008, 04:57 PM
FredTJ's Avatar
Did you at least drop the pan from the tranny and take a look inside before you installed the used tranny ?
If the donor had any miles at all to speak of, you should use a new/rebuilt TC.
Fred
Old 12-13-2008, 05:00 PM
Sponsor
Tofer's Avatar
the tranny i bought has paper work show a fresh rebuild
Old 12-13-2008, 05:09 PM
FredTJ's Avatar
So it's a new rebuild with 0 miles on the rebuild ?
And, if so, they gave you a used TC ????
Fred
Old 12-13-2008, 05:30 PM
Sponsor
Tofer's Avatar
well fresher... i cant remember it it was 3000 or 30,000 miles ago... i bought it from my buddy who bought the truck with a blown HG.... he has the paper work on it.
Old 12-14-2008, 06:22 AM
It's not the TC. Your shift solenoids are not working. Did you plug in all the electrics?
Quick Reply: normal auto slugg or did i do something wrong
