Noisy Valves
Old 07-19-2010, 09:19 AM
JPizano23's Avatar
Noisy Valves
I go a 1995 4Runner w/a v6, she has about 190,000. The engine hesitates when I step on the gas, and the valves are pretty noisy when I go up a hill or when I speed up. I think that I need to have my valves adjusted but I want to make sure this engine will last before I spend 400 for a valve job plus another 250 for an oil leak she has. I know toyotas are known to last, is it recommended to do this on an engine with these many miles?
Old 07-19-2010, 06:15 PM
norcal707's Avatar
are you doing this job yourself or someone else?
Old 07-19-2010, 06:16 PM
pruney81's Avatar
Toyota 20R/22R motors are known to last, I wouldn't dump any more money into a 3VZE than I absolutely had to to keep it running.
Old 07-19-2010, 06:25 PM
norcal707's Avatar
3VZE engine is not too bad....my 4runner has 203k miles, just put new headgaskets and adjusted the valves. now it runs little better. if you thinking of keeping your 4runner for a while, I would. have you ever replace the headgaskets on yours?
Old 07-20-2010, 05:11 AM
JPizano23's Avatar
I'm going to have a shop do the work. So far the dealer has quoted me 475 and two independent shops are asking 375 and 410 for labor and seals on the valve covers and plenum. I intend on keeping this thing until she won't drive and then I'll probably get a used engine from Japan. I haven't replaced the head gasket, I was thinking about it; what are the symptoms she needs one? I just replaced the plugs, they were clean there's no oil leaks except for the oil pan.
Old 07-21-2010, 10:10 PM
PismoJoe's Avatar
Im not a 3vz expert but I hear the injectors are noisy in those. Probably wouldn't hurt to check the valve lash, if you are mechanically inclined a bit you should get your on and save some hard earned!
HG blown= white smoke from exhaust, sweet smell, bubbles under oil cap, chocolate milkshake looking oil....youll know when it goes lol
LotOMiles
09-14-2015 11:45 PM
ac7822
09-11-2015 08:49 AM
Boomer8404
09-10-2015 09:01 AM
idadan208
09-07-2015 09:06 AM
Quick Reply: Noisy Valves
