No start/power after HG replacement 22re
Old 06-10-2012, 01:22 PM
Jared!'s Avatar
OK guys I have a weird issue going on. I bought this '95 22re and after about 40 miles on the way home the HG went. Fast forward to this month, Ive replaced the HG and a new head with cams from Engnbldr. I go to crank it up and I get about 45 seconds worth of cranking and then nothing. No dome light, no door buzzer, nothing. Ive checked/replaced all my grounds, its got a brand new battery/terminals, and all of my fuses are good. Ive been getting frustrated with it since it was supposed to be my main transportation other than my motorcycle. Any ideas or suggestions on things I need to check out? Let me know if you guys need any more info. Im supposed to be moving at the end of july and Im trying to get this old girl on the road before resorting to towing it to a dealer and having them handle it.
Old 06-11-2012, 05:52 AM
Jared!'s Avatar
Anyone? Bueller?
Old 06-11-2012, 06:52 AM
snobdds's Avatar
Since there is little information here to base anything on...If I had to wager a guess, I would say your timing is off.
Old 06-11-2012, 07:10 AM
Kiroshu's Avatar
So your saying you can crank the engine over for limited time then you loose all power?
I would say theres a poor connection/grounding somewhere. You wanna make sure all of your grounds are back exactly where they are supose to be this is important. Toyota knows best.
Old 06-11-2012, 07:59 AM
Jared!'s Avatar
Welp I figured it out, after going over my grounds for the hundredth time and checking my my power wires, I found a bad male connector under the 80A fuse. I have full power back and she turns over like a champ. I still gotta get her some fresh gas and new plugs and she should be running like a champ. Thanks for the responses guys.
mskalmus
05-28-2017 07:51 AM
MMA_Alex
25
04-18-2017 05:07 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Nickdigg
07-07-2015 06:04 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: No start/power after HG replacement 22re
