No Fuel Again...
Old 01-11-2010, 09:46 AM
Lumpy's Avatar
It was a bit chilly for a skirt this weekend, it's nice I can wear pants again!!!
Here is a interesting find...When I checked the voltage at the wires by the pump I was getting 8 volts. I tested the wires coming out of the splice I fixed last year and the wires were a bit smaller than the wires coming from the pump and from under the cab. So I cut all that out and replaced some of the wire with the correct size.
Since this has been done I've noticed more pull at WOT and I'm also using more fuel. I think the pump has never gotten the full 12V like it should have gotten so it was not supplying the correct pressure there for she was a bit sluggish. I had not noticed because it was like this when I got it.
Upside more power
Downside uses more fuel
Old 01-11-2010, 03:57 PM
1990yota-pickup's Avatar
that would do it.. sounds like you got it fixed
wafoogalla
11-02-2016 11:02 AM
daddio
08-09-2015 07:17 PM
Hiluxtrucha
07-22-2015 10:00 AM
Fundy Rider
07-16-2015 01:35 AM
shisha1999
07-13-2015 11:09 PM
Quick Reply: No Fuel Again...
